Author Topic: Chrome bezel came off tachometer  (Read 95 times)
CJHenderson
  • USA, AR, Benton
« on: Today at 00:33:12 »
When installing the tachometer, the chrome bezel fell off. Ordered a new one, just like the old one which I crimped on I would most likely have the same problem. Would it work if I placed the tach face down an apply a thin adhesive between the bezel and body of the tach?
1950 MG-TD
Re: Chrome bezel came off tachometer
« Reply #1 on: Today at 04:37:57 »
Why would it come off if you crimp it? I understand you use the round grey gasket\liner that goes there between speedo and dash? It is just hand tight fixing, the bezel should not come off when crimped…
« Reply #2 on: Today at 07:08:31 »
As Pawel says, and for that matter you should be able to crimp the old bezel back on without issue also.
