Author Topic: No brakes with engine running  (Read 176 times)
RobParkerMB
  • United Kingdom, England, Taunton
« on: September 14, 2025, 06:59:00 »
I've recently replaced all of my brake components. I have bled them, and with the engine off I have a pedal, as soon as I start it, there is nothing, literally nothing at all, it's like the pedal isn't even connected. Have I still got air in there somewhere? I don't get alot of fluid out of the rear bleed nipples.
1964 230sl
1998 sl320
2003 e320
2010 e350
rogerh113
  • Los Altos, Ca
Re: No brakes with engine running
« Reply #1 on: September 14, 2025, 17:16:39 »
I think that the only connection between the braking system and the engine (running or not) is the brake booster.
You might want to check the plastic fluid trap in the air line between the booster and the intake manifold, and see if it is loaded with brake fluid.  Not sure how this could cause the problem, but would indicate something failed within the booster.
Could be that the engine vacuum is fully triggering the brake booster (full braking), or the booster is seized in full braking mode, and that is why there is no pedal left.  Is there pedal feel when the engine is turned off?
You should be getting good flow out of the rear bleed nipples.  Did you replace the rubber brake hoses?  Those could be old and blocked.
regards -- Roger
RobParkerMB
« Reply #2 on: September 14, 2025, 20:31:46 »
Thank you. I will check that fluid trap, although as you say I can't see why it would cause my issue.
I can't even see if the booster had failed that it would cause my issue, I would think it would give a hard pedal.
I wonder if with the power of the booster it's emphasising air in the lines that haven't bled properly.
Yes all hoses are new. It's abit of a head scratcher
1964 230sl
1998 sl320
2003 e320
2010 e350
hemibeep
  • USA, FL, Oldsmar
« Reply #3 on: September 14, 2025, 23:45:12 »
I am also working through new brake system.
Master cylinder was hard to bleed.
If you have pedal with engine off, then no pedal with engine running, you probably still have air in system. Booster is power assist and multiplies pressure to MC.
The front brakes are easy to bleed by simply turning the wheels one at a time. perhaps try with car running.
Should always start with passenger rear, then other rear, then pass front.
good luck
1970
RobParkerMB
« Reply #4 on: Today at 06:22:45 »
You wouldn't think bleeding brakes would be so hard! Had the same trouble on a 203 years ago.
Good luck to you as well
1964 230sl
1998 sl320
2003 e320
2010 e350
« Reply #5 on: Today at 07:17:26 »
My guess is you were not using a vacuum or power bleeder?
