Become a
Full Member
Emergency Contact List
Power steering reservoir overflowing
Topic: Power steering reservoir overflowing (Read 254 times)
johnk
Full Member
Platinum
USA, OH, Avon
September 12, 2025, 01:33:32 »
My power steering reservoir is overflowing through the top. I understand from searching this site that it is most likely caused by an air bubble in the system. Following what was recommended here I raised the front of the car and turned the steering wheel left and right several times with the engine running. It still leaks. Should I do it again for a longer period of time or try something else?
I really appreciate the help!
John K
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Power steering reservoir overflowing
September 12, 2025, 06:52:37 »
Turn your engine off while turning your steering wheel from side to side.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
johnk
Full Member
Platinum
USA, OH, Avon
Reply #2 on:
September 12, 2025, 12:14:56 »
Thanks Doc
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Vander
Full Member
Silver
USA, OH, Columbus
Reply #3 on:
September 12, 2025, 13:21:32 »
If that doesn't work, bleed the steering gearbox. With the car running, and all 4 wheels on the ground there is a bleeder screw on the top of the gearbox, use a socket. It looks just like a bleeder on a brake caliper.
Vendor
Platinum
USA, TX, Dallas
Reply #4 on:
September 12, 2025, 19:33:52 »
You can also run a hose from the bleeder back to the reservoir. When the bubbles stop, system bled. You don't want to fill the reservoir all the way to begin with. Leave it about half way full until all of the bubbles are gone. You only need just enough fluid while bleeding to prevent sucking in air to the pump from the reservoir. After it is bled, fill it up to the mark.
johnk
Full Member
Platinum
USA, OH, Avon
Reply #5 on:
September 13, 2025, 03:08:32 »
Thanks gents
I tried it with the engine off before but not enough times. This time I left the top off the reservoir and could see the bubbles escape. I kept on turning the wheel until all air was gone. Worked like a dream!
John K
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
