Author Topic: 250 SL restoration  (Read 288 times)
Bobe
  • France, Pays de la Loire, nantes
250 SL restoration
« on: September 04, 2025, 07:23:55 »
Hi There,
I told the forum back in April about the refurbishment process of my ’67 250 SL. The first part, the engine and the front part of the chassis is nearly completed. I should get the car back by the end of September., which is roughly according to the expected delivery time ;D. A lot has been done, and the engine bay has been resprayed while the engine was out. The good news is that there were only very light rust marks in the bay, no perforation and no serious corrosion  ;D. The hydraulics of the power steering was redone, the water pump changed and the alternator replaced. The timing chain was cheched. An electronic ignition is also installed.
The last part to do at this stage is to change the power break unit; leaking and not working anymore and that should be completed next week. The cold start issue should also be fixed.  The gear box has been overhauled, and the underneath anti rust cover of the car has also been redone: this was not planned initially but whilst the engine ger box and transmission was away, it was a good time to do it. Again, no bad surprises there, only tiny signs of light corrosion that needed to be treated before it gets bad. I have since purchased 3 skins of a beautiful crème leather and once I get the car back, a saddler will deal with the interior. The external paint and underneath coat the rear of the chassis will be redone next year. Results so far are stunning! I attach pictures of the work.
250 SL '67 horizontblau
280 SE '79 Champagne
Citroen 2CV 6 special '83 Rouge Vallelunga
Bobe
Re: 250 SL restoration
« Reply #1 on: September 04, 2025, 07:31:05 »
Additional pictures, with the engine back to where it belongs. The chassis and wheel wells were covered with an anti rust epoxy, then with a rubber protection and finally resprayed in the body colour.
Bobe
« Reply #2 on: September 04, 2025, 08:25:15 »
The only bad surprise was that the drain behind the left front wheel well was removed or lost at some point and the hole was filled so that some water could stay inside. I could not see it myself but the expert eye of the workshop owner saw it at the first sight. It was necessary to replace this area with a steel plate of around 3 sq inches. Might be good to check regularly this spot.
