Author Topic: Fuel issues, please help a newbie!  (Read 289 times)
RobParkerMB
  • United Kingdom, England, Taunton
« on: August 31, 2025, 15:56:04 »
Skipping most of the story, I have no fuel coming out of a couple of IP outlets. Can you see in this picture a stuck plunger, or do I have to remove more parts?
Out of the two with their fittings off, the left one was producing fuel, the one on the right was not. Yet both looks the same. And nothing moves when turning the engine by hand.
I'm a decent home mechanic but haven't worked on one of these before so I don't fully understand which bits are meant to move and not.
Any help greatly appreciated.
1964 230sl
1998 sl320
2003 e320
2010 e350
Re: Fuel issues, please help a newbie!
« Reply #1 on: August 31, 2025, 19:22:13 »
I'm sure you'll get some good advice.
I'll say that I've been in this group since before we started a website 23 years ago. I'm a basic DIY mechanic who's brave enough to try new things.  I wouldn't touch the inside of the fuel injection pump without multiple experience people agreeing on the same advice and instructions. Tread lightly.
RobParkerMB
« Reply #2 on: August 31, 2025, 19:42:47 »
Well it already doesn't work so I have little to loose before forking out 3k for a refurbished one
1964 230sl
1998 sl320
2003 e320
2010 e350
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #3 on: August 31, 2025, 20:39:00 »
There is more than 1 type of injection  pump in these cars so it would be helpful to get more information.
Here is one thread that has a lot of info
https://www.sl113.org/forums/index.php?topic=886.0
Lori
1968 280SL (US)
« Reply #4 on: August 31, 2025, 23:40:40 »
And, once you join as a full member:
https://www.sl113.org/wiki/Fuel/Injection
« Reply #5 on: September 01, 2025, 04:49:26 »
Your looking down on the check-valve assembly. It  threaded on the outside. Find a fitting to scew onto it so you can pull it out. Below you will fine a cylinder and plunger (piston). The pistons get stuck in the up position and then do not pump fuel and cause the rack to stick also. Use penetrant and a blunt soft metal or hardwood drift to knock the pistons downward. Turn the engine and repeat until the pistons return down on their own. Eventually you may be able to free them up. When the pistons become free the rack will move freely also! Re-install the check valves. Torgue the fittings in place to 21 ft/lbs. (important)
RobParkerMB
« Reply #6 on: September 01, 2025, 06:01:19 »
Really helpful advice from everyone, thank you.
I have ordered what I think is the right thread to pull out the check valves, so will give that all a go.
I've just replaced all the fuel lines, electric pump and the tank itself, so I'm really hoping this will now get it going.
1964 230sl
1998 sl320
2003 e320
2010 e350
BobH
« Reply #7 on: September 01, 2025, 08:22:00 »
Hello Rob, there are a couple of helpful links on here
https://www.sl113.org/forums/index.php?topic=39147.msg285761#msg285761
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
RobParkerMB
« Reply #8 on: September 01, 2025, 13:27:37 »
1964 230sl
1998 sl320
2003 e320
2010 e350
« Reply #9 on: September 01, 2025, 21:33:35 »
How do these pistons normally return down?  Spring?  Vacuum below?  Fuel pressure above?
« Reply #10 on: Today at 04:23:01 »
They return back down from a spring below.
