with our official
Pagoda SL Group logo
from our official partner.
One Cylinder Not Firing
Topic: One Cylinder Not Firing (Read 401 times)
rbouch8828
Full Member
Silver
USA, MA, Framingham
280SL Mfg date AUG 1969
August 27, 2025, 19:49:35 »
Is there an easy way to tell whether the problem is with an Injector or on the Spark side?
RB
Paul & Dolly
Full Member
Gold
United Kingdom, Wales, CARDIFF
i Car
Re: One Cylinder Not Firing
August 27, 2025, 20:48:53 »
Swop the plug with another one and see if you get improvement.
Swop over two injectors and see if the problem moves with the swop.
Good luck
Paul
1967 Early 250 SL (Auto) White
Mitsubishi i Car
Toyota RAV 4 Hybrid AWD
rbouch8828
Full Member
Silver
USA, MA, Framingham
Reply #2 on:
August 27, 2025, 21:15:30 »
Thanks Paul
RB
Full Member
Platinum
USA, CA, DeLuz and France, Haute-Marne, Guyonvelle
Reply #3 on:
August 28, 2025, 04:40:13 »
Take out the spark plug from that cylinder and see whether it is wet with fuel. If so, it's likely not the injector. If dry, then crack loose the tube going to the injector to see if fuel comes out when the engine is running.
rbouch8828
Full Member
Silver
USA, MA, Framingham
Reply #4 on:
August 29, 2025, 17:08:37 »
I don’t know which cylinder it is. I first need to find out which is the one that isn’t firing.
RB
Full Member
Platinum
Reply #5 on:
August 29, 2025, 19:08:08 »
To find that out, either use an infrared heat gun aimed at the exhaust manifold connections to each cylinder: the one not firing will be much cooler than the others. Or pull each spark plug lead off the plugs one by one with the engine running. The one not affecting how it runs is your culprit.
rbouch8828
Full Member
Silver
USA, MA, Framingham
Reply #6 on:
August 29, 2025, 19:49:53 »
I was planning to pull the spark plug leads to do that check. Hope it turns out to be a bad plug and not something with the fuel pump.
Thanks!
RB
Full Member
Platinum
USA, OH, Canal Winchester
Pagoda SL Group: 20+ years and going strong!
Reply #7 on:
August 30, 2025, 14:45:40 »
Yes, pull spark plug leads (safely!) one at a time until you find the one that
doesn't
disrupt the idle.
rbouch8828
Full Member
Silver
USA, MA, Framingham
Reply #8 on:
August 30, 2025, 14:51:33 »
Thanks, will give that a try!
RB
