Author Topic: Hard top hoist for storage  (Read 2855 times)
Merc_Girl
« on: August 26, 2025, 10:16:15 »
Hi everyone!
So, my husband has selfishly parked his 1972 Fiat Cinquecento back in MY garage!!! Whilst Bessie’s hard top wraps around the Fiat to some extent, we are now rather bored of ‘dancing around’ it all the time.
I see there have been a few discussions around hoists, particularly this chat https://www.sl113.org/forums/index.php?topic=33106.0.
So my questions are:
- is it ok for hardtop to be stored in such a way? Mindful there are comments about the pinching of the rubber seals?
- can anyone recommend a manufacturer/ supplier (baring in mind I’m in the UK
- are any available with a powered hoist, thinking of the future and old age!!!!
As always, help always gratefully received 🥰
thinking of future or
230SL
Alf
  • England, Surrey, Lightwater
Re: Hard top hoist for storage
« Reply #1 on: August 26, 2025, 11:25:57 »
Great post Merc_Girl. I’m very interested in the answers too!
Alf
'69 280SL. Silver (180 G) with black hardtop
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« Reply #2 on: August 26, 2025, 13:40:47 »
Hi
I built the support myself inspired by models sold by professionals, but which I found expensive, and I bought the manual winch separately in a DIY store.
If you’re interested, I can share the measurements with you. No welding is needed — everything is assembled using screws and nuts. The winch is manual, but it doesn’t cause any physical problems (especially considering how frequently it’s used, it’s not really an issue...).
Indeed, the seal at the bottom of the hardtop tends to get crushed... but I think mine are original, and if they are newer, I believe the effect is lessened. Moreover, once put back in place and given a bit of time, the seal regains its original shape...
Would you like me to make it a bit more formal or casual?
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
su8pack1
  • USA, PA, Barto
« Reply #3 on: August 26, 2025, 17:03:59 »
I built this lift over 40 years ago with a hand crank, and it still works fine.
1984 300CD
1987 190E 2.6
1988 190D 2.5
Merc_Girl
« Reply #4 on: August 26, 2025, 21:47:11 »
Obviously a lot of clever chaps out there, unfortunately I’m somewhat lazy when it comes to this 😂
230SL
« Reply #5 on: August 27, 2025, 00:26:28 »
MercGirl,
Be patient, get lots of feedback before buying.
Who was the member in Australia who's hoist failed?  It was the type that clamps on the chrome trim, I believe.
For DIY, that seems be the most precise to make on your own.  I would think a good DIY solution would be to support at the inner roof handles and the rear pin.  Then, find the balance point above the top with straps.
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Last Edit: August 27, 2025, 12:07:48 by Lori »
Lori
1968 280SL (US)
« Reply #7 on: August 27, 2025, 04:25:40 »
Tried the one from the first link - not very seals and top upholstery friendly.
I am using the one from he second link.
Figoulu
« Reply #8 on: August 27, 2025, 08:07:14 »
I believe I somehow copied / pasted this one to build mine...
1965 230 SL
Paul & Dolly
  • i Car
« Reply #9 on: August 27, 2025, 09:43:20 »
Katie,
Are you planning to store it on a stand, or Hanging in the air ?
I use an Audi Hoist, slightly modified, it came with a crank handle, but I use a Ryobi Drill with a hook to turn it.
I am not keen on the hoists that use the gutters to attach to the Hardtop - it weighs 50 Kg, mine lifts from below.
Have fun
Paul & Dolly
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
RAY
  • United Kingdom, England, Bromley
« Reply #10 on: August 27, 2025, 17:54:21 »
Hi Katie,
I made one up using the exact same gutter clamps as su8pack1 but with an aluminium box section instead of wood and doubled up on the clamps and bars so dont have to worry to much about the balance point and no chance of it failing. I lift it off and on with an electric winch and store it in a hard top roof stand. Been a success for ten years now, no dings in the paint work, angle it so you locate the front levers first.
GM
  • USA, CO, Boulder
« Reply #11 on: August 27, 2025, 19:07:00 »
If you run out of suggestions, although in the US, this worked for me.
Ignore the listing of cars, it works on a W113...
https://www.top-hoist.com/
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
« Reply #12 on: August 27, 2025, 19:23:50 »
More data points to consider.
Being nervous about the weight of the hardtop, I purchased mine.  See some of the cautionary notes from the Manufacturer attached.  I also was fearful of pulling the winch reel from the wall, so it is lag bolted across beams.  Note in the pix that the winch can connect to a drill/socket for operation.  Just  some more input for you
JB
« Last Edit: August 27, 2025, 22:52:54 by John Betsch - "SADIE" »
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
« Reply #13 on: August 28, 2025, 03:46:13 »
If you are going to be using any additional hooks, blocks or pulleys, do not buy cheap chinesum ones, buy only weight rated ones, e.g. marine ones, no matter how solid the chinesum ones look like.
