Author Topic: Fuel line sizes.  (Read 3867 times)
su8pack1
  • USA, PA, Barto
Fuel line sizes.
« on: August 23, 2025, 00:56:11 »
1969 280SL. What size OD feed and return fuel lines have any of you used? In inch mesurements. I ordered a pair from a vendor, but you have to make all the bends yourself. I did but the return line is steel and very hard to bend even with the correct tools. I ended up kinking the 45° bend that goes over the rear axle. I'm thinking aluminum lines. I ordered a hydraulic hand bubble and flare tool as the hand tool I have is a killer to make the bubble end in a steel line. Any recommendations on size and thoughts on using aluminum lines.  My research comes up with several different sizes. Thanks.
1984 300CD
1987 190E 2.6
1988 190D 2.5
Re: Fuel line sizes.
« Reply #1 on: August 23, 2025, 06:03:46 »
su8pack1
  • USA, PA, Barto
« Reply #2 on: August 23, 2025, 12:37:17 »
Thanks for that link, I missed that one. Any thoughts on aluminum lines? I see they're used on many other cars, as they are just easier to shape.
1984 300CD
1987 190E 2.6
1988 190D 2.5
TJMart
  • USA, NC, Matthews
« Reply #3 on: August 23, 2025, 14:55:41 »
I installed all new brake lines on my car and used Copper/Nickel lines using the Eastwood Tool to flare the ends mentioned in the above post. I don't see why the copper/nickel lines would not work on fuel lines. They are much easier to bend and flare with the proper tools and will not rust. I was very happy with the results.
Tony
1970 280SL, 4 Speed
merrill
« Reply #4 on: August 24, 2025, 14:56:01 »
hello
about 20 years ago i replaced all the fore to aft lines on my sl.
brake, fuel return, fuel send.
at that time i believe i was able to order all 3 lines from the dealership which arrived in a coil.
first step was to un roll and straighten the lines as best i could.
 I think i taped one end to the garage floor and then carefully un rolled keeping the coil as steady as possible and using a foot to keep the line in place as i un rolled.
i ended up bending the lince by hand,   i would tape one end of the original line to one end of the new line
then, slowly working my way down i would bend by hand (maybe using a tool here and there)  and taping the lines
together about every foot or so.
once i got to the other end, i would to back to the start and double check.
the most fun was re installing all 3 lines in the car.    new clamps and rubber etc.
hope this helps
j
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
su8pack1
  • USA, PA, Barto
« Reply #5 on: August 26, 2025, 03:46:28 »
Yes, thanks.
1984 300CD
1987 190E 2.6
1988 190D 2.5
su8pack1
  • USA, PA, Barto
« Reply #6 on: September 04, 2025, 22:43:47 »
Finally got my fuel lines done. After getting the lines bent the new steel line ended up 6" to long so I had to cut that off which then required a new bubble flare for the rubber hose to connect. After going through 2 of the cheaper kits that couldn't flare the steel return line I bought the Mastercool Universal Hydraulic Flaring Tool Set which did the job. Expensive but worked good.
1984 300CD
1987 190E 2.6
1988 190D 2.5
su8pack1
  • USA, PA, Barto
« Reply #7 on: September 04, 2025, 22:45:16 »
Pic
1984 300CD
1987 190E 2.6
1988 190D 2.5
su8pack1
  • USA, PA, Barto
« Reply #8 on: September 04, 2025, 22:45:56 »
Pic
1984 300CD
1987 190E 2.6
1988 190D 2.5
su8pack1
  • USA, PA, Barto
« Reply #9 on: September 04, 2025, 22:46:26 »
pic
1984 300CD
1987 190E 2.6
1988 190D 2.5
su8pack1
  • USA, PA, Barto
« Reply #10 on: September 04, 2025, 22:47:00 »
pic
1984 300CD
1987 190E 2.6
1988 190D 2.5
« Reply #11 on: September 05, 2025, 02:45:54 »
Silly question - why/how do metal fuel lines "go bad"?
« Reply #12 on: September 05, 2025, 11:30:16 »
Steel fuel lines, like any other steel part (particularly anything living in the menacing underside of a car) can rust.
Pure copper (along with other metals) can possibly “work harden” and crack or break when subjected to stresses.
Either situation perhaps rare…but it does happen.
su8pack1
  • USA, PA, Barto
« Reply #13 on: September 05, 2025, 12:09:39 »
After finishing the water pump, and crank shaft seal replacement I had the engine running for a few minutes and noticed a puddle around the back driver side tire. Gas. Both lines had a pin hole in them and were leaking. A couple years ago I replaced all the brake lines and rebuilt all the calipers and 4 new tires and battery. About 12 years ago I replaced the fuel pump, cleaned and sealed the gas tank. 6 years ago I replaced the injectors and had the injector pump rebuilt. I bought the SL back in 1982 and she's a good car, but like any other it takes a lot to maintain it.
1984 300CD
1987 190E 2.6
1988 190D 2.5
« Reply #14 on: September 05, 2025, 13:49:13 »
Ok then.  I guess metal brake and fuel lines are now on my yo do list.
su8pack1
  • USA, PA, Barto
« Reply #15 on: September 07, 2025, 01:56:01 »
Finished. All new fuel hard lines, and rubber lines hooked up. That took some time.
1984 300CD
1987 190E 2.6
1988 190D 2.5
« Reply #16 on: September 07, 2025, 11:16:05 »
With nice and proper clamps! 👍👍👍
merrill
« Reply #17 on: September 09, 2025, 15:19:37 »
one tip would be to clear spray paint the lines before and after installing.
help to protect the lines and hopefully prevent corrosion.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
su8pack1
  • USA, PA, Barto
« Reply #18 on: September 09, 2025, 19:30:00 »
Good idea, thanks.
1984 300CD
1987 190E 2.6
1988 190D 2.5
