Author Topic: Advance curve for 280 with 123 ignition ?  (Read 183 times)
yves
  • France, Poitou-Charentes
« on: August 05, 2025, 09:40:53 »
I try to adjust the curve for my 123 ign
With the one attached.
Am i correct?
I have adjusted the static advance with  5 deg advance
Re: Advance curve for 280 with 123 ignition ?
« Reply #1 on: August 05, 2025, 11:30:33 »
yves, I am attaching what I use (courtesy of a Member here), but there are also posts about this topic if you do a search.
I have 6deg advance.
I guess in higher revs you may go up to 38deg total if it is not pinging, I left it a bit lower.
Best is to go through search and related posts.
yves
« Reply #2 on: August 05, 2025, 21:07:07 »
Thank’s Pawel, your’ right about more advance to higher revs , manu told me to adjust 30 degres at 3000 revs
« Reply #3 on: August 06, 2025, 07:25:31 »
Which is correct if you have the vacuum advance disconnected. This is what the factory recommended. Once set you then re-connect the vacuum advance and confirm you've now got 38°.
« Reply #4 on: August 06, 2025, 07:31:11 »
« Last Edit: August 06, 2025, 07:40:44 by Pawel66 »
