Author Topic: Automatic Transmission Ball Socket  (Read 1438 times)
Klaus Pieper
  • South Africa, KwaZulu-Natal, Westville
« on: August 01, 2025, 12:43:24 »
I am having great difficulty in removing the lower ball socket on the automatic transmission, firstly because access through the transmission tunnel is tricky and secondly because the part to which the ball socket attaches has come loose from the gear box side and hence there is very little leverage space to remove the ball socket from this part. The ball socket, according to the parts book, has an internal securing clip.  Is there a special way to remove ball sockets with internal securing clips?
I would greatly appreciate your views.
Re: Automatic Transmission Ball Socket
« Reply #1 on: August 01, 2025, 18:47:25 »
Best I know is that the internal securing clip can only be 'overcome' with a bit of extra force, both going in and popping back out. If you can squirt some penetrating fluid in the connection, that could make all the difference. Probably dirt and corrosion affecting things.
« Reply #2 on: August 01, 2025, 22:24:59 »
The small wire clip must be removed before it will come apart. Almost no way you can pry it off without removing the clip.
« Reply #3 on: August 02, 2025, 04:07:29 »
I stand corrected, thanks Dan.
Is there a picture of what we're talking about? All I am familiair with in terms of 'internal retaining clips' are those one can't even reach when the joint is connected.
Klaus Pieper
« Reply #4 on: August 02, 2025, 14:57:53 »
Thank you all for your prompt replies.  I think Dan is correct that without removing the securing clip the ball socket can not be removed.  From my limited visibility, the securing clip wraps around the outside of the ball socket arm and then feeds through a very small hole into the ball socket cup - where it feeds to inside the socket cup I could not yet establish.  I will try and remove this clip without hopefully destroying it on Monday.  I will keep you posted.
Unfortunately I have not yet fathomed out how to load a photo on this wonderful forum.
« Reply #5 on: August 03, 2025, 03:24:33 »
Attached pic is on Android phone.  Below the white text box is a tiny "+" button next to "Attachments and other options".  Click the "+", browse to your image file, and select it.  There are some file format restrictions, size restrictions.  Max 4 attachments per message.
Klaus Pieper
« Reply #6 on: August 06, 2025, 17:18:46 »
Thanks Rodd,
with a lot of help from the family, here finally are the pictures.
BobH
« Reply #7 on: August 06, 2025, 20:38:23 »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Klaus Pieper
« Reply #8 on: August 07, 2025, 07:01:33 »
Thank you very much BobH, that surely helps..  I am confident that I can now resolve the issue.
« Reply #9 on: August 07, 2025, 08:13:47 »
I think part number for the retaining clip may be A 113 268 00 73. It is not on the drawings, but it is in the parts list. It is more proforma as it may not be available most likely at Mercedes (availability not determined, ask dealer). But maybe it is better to know the part number than not to know it...
Klaus Pieper
« Reply #10 on: August 07, 2025, 09:33:16 »
Thank you Pawel.  My M-B Chassis and Body Spare Parts List shows the part no. as 071 805 008 400.  The part is available for order at Niemoeller.
BobH
« Reply #11 on: August 07, 2025, 09:38:15 »
Some pictures on here if they help you or others
https://www.sl113.org/forums/index.php?topic=37355.msg273232#msg273232
UK delivered RHD
Blue soft top
Blue leather
« Reply #12 on: August 07, 2025, 12:57:56 »
It is under DIN number there, that may offer some opportunities as it is a generic part. You are right, I was looking for it in a wrong place (shift lever linkage).
The alternative PN to N 071 805 008 400 is A 094 990 02 14, but also not available at Mercedes.
In case of trouble obtaining, if you google DIN 071805, it should yield some results.
« Reply #13 on: August 07, 2025, 20:45:45 »
Books are great!!!  I wish more Pagoda owners had more reference books.
« Reply #14 on: August 07, 2025, 22:34:31 »
Books are great, but the part was in EPC as well, I just looked in the wrong place. EPC will show you part history, changes and when it was applied. I can live without books, I cannot imagine living without EPC...
« Reply #15 on: August 07, 2025, 23:57:08 »
Can anyone access EPC for a simple fee?
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #16 on: August 08, 2025, 00:30:23 »
I use this free site
https://nemigaparts.com/cat_spares/epc/
(Ignore the prices, they are out of date)
Lori
1968 280SL (US)
« Reply #17 on: August 08, 2025, 05:06:06 »
I guess you would have to ask your nearby dealer. It is now called B2B. Gives you prices and you can order directly.
« Reply #18 on: August 08, 2025, 11:35:51 »
I am not a B, so maybe I'm out of luck there.
« Reply #19 on: August 08, 2025, 14:53:31 »
I understand, I am not a B either, you do not have to be a B.
They gave access to me on their initiative years ago when I started restoring my Pagoda. I tormented them with orders, they figured it will be easier if I just find parts myself and just send them order. I got huge discount together with is at that time that I keep today.
