Author Topic: Pinion Seal Housing  (Read 393 times)
rasch
  • USA, CA, Torrance
Pinion Seal Housing
« on: July 21, 2025, 18:32:39 »
I have removed my rear differential to update seals, wheel bearings, bushings... but I never opened the differential which itself seems to be in solid condition.  It was leaking from the front, and I intend to replace the pinion seal.
My question is, does the pinion seal housing ever leak?  Is removal and reinstallation straight forward or do I need to worry about anything that is not obvious?  Since the axle is out, I want to take care of anything that could be a problem now, but I also don't want to fix something that isn't broken and create an unintentional problem.  From my experience differential covers don't leak that often but I also have read of a recommendation to remove the front housing cover.
Thanks!
« Last Edit: July 23, 2025, 05:56:00 by rasch »
Robert
1967 230sl
Re: Pinion Seal Housing
« Reply #1 on: July 21, 2025, 20:04:36 »
https://www.sl113.org/wiki/DriveShaft/Differential
When you get your details and get the work done, perhaps you could add an entry here to help members with future repairs.
Is the silver color just a personal preference or did a restoration shop do that?
rasch
  • USA, CA, Torrance
« Reply #2 on: July 21, 2025, 20:18:10 »
I see what you mean... however, the color is actually black. I think it just looks silverish in the photo due to reflected light or maybe it being overcast.  I painted it myself using black epoxy primer/sealer and Eastwood chassis black as a topcoat.
Robert
1967 230sl
« Reply #3 on: August 06, 2025, 05:03:37 »
The two machined surfaces are not normally a source for leaks. I believe that no gasket is used, just sealer.
