Author Topic: HELP! Can’t remove gas cap.  (Read 4992 times)
yves
  • France, Poitou-Charentes
Re: HELP! Can’t remove gas cap.
« Reply #25 on: July 19, 2025, 06:45:56 »
On the A part, i had some issues with the spring which actuate the sliding tab, it go out its location very easily....!
And may be the missing  part i made is not functionnal?
« Reply #26 on: July 19, 2025, 09:33:54 »
Can you find the edges in the bottom of the inner piece under the gasket?
Is it possible to stick a pinch or screwdriver against one of these edges and drive the cap open with a hammer?
The inner part where these edges are is locked to fuel neck only by spring force and gasket friction, nothing else…
BobH
« Reply #27 on: July 19, 2025, 12:32:16 »
As a very last resort, if the garage can't fix the problem, a very small hole drilled in the side of the knurled part of the spinning top, into the body of the cap, and insert a small pin, to lock the parts together, hopefully will be inobtrusive
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
lreppond
  • USA, CA, San Leandro
« Reply #28 on: July 19, 2025, 16:00:41 »
I suspect it is the spring that is causing this problem.  Probably out of alignment and therefore not pushing the tab far enough to get a positive lock between the outer and inner cap.
BobH’s idea of drilling through the outer and inner caps and locking them together by screw or nail seems like the only solution left. I am anxious about drilling through metal so close to gasoline!
Pawel's idea of driving the cap off with a punch or screwdriver is a good one except there is absolutely no room to do it.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
49er
  • USA, CA, El Dorado Hills
« Reply #30 on: July 19, 2025, 17:30:21 »
Hello Len, Have you removed the Bumper? you might have more room to get to the cap from the bottom especially if you will be using a power tool to drill.
John
1969 280SL 003820
4 speed manual, PS. 77K+miles
7K+ miles since awoken from her 20+ yr "nap" in 2010
« Reply #31 on: July 20, 2025, 08:13:49 »
Keep thinking about it, for what it is worth…
If you could find something to squeeze the sides of the chrome cap so that they rest against the inner piece and try to turn it… like a large vice grip.
Te investment for removing surrounding parts, such as bumper, lamp, maybe register plates lamp trim may really be worth considering.
I would make sure, as 49er is suggesting, before any drilling, to check if surrounding parts removal is not opening opportunities to use some other opening method than destruction.
If you have original key to use with the cap, the tumbler is the part to protect, more than a chrome cap.
Sorry if I am saying obvious things…
« Reply #32 on: July 20, 2025, 08:18:11 »
Another silly thought: is there a hope for some space and access from inside the trunk?
Removing the cover, prying out the rubber seal should open the hole in the trunk wall so that you can see the cap from its bottom side. Not sure if there is enough space to stick anything there and try to turn the cap…
Anyway: maybe removing the rubber seal that seals the fuel filler tube to the body may offer some access, as I look at the pictures.
yves
« Reply #33 on: July 21, 2025, 09:28:18 »
In the photo #18 i Said an error🙄 in that location of the sliding tab ,the part A Turin WITH the B part and you can open thé cap.
lreppond
« Reply #34 on: July 21, 2025, 16:21:05 »
The car is at the shop I use for gas cap removal and a few misc chores that need to be done.  Hopefully they will have better luck than I did!
« Last Edit: July 21, 2025, 16:39:19 by lreppond »
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
lreppond
« Reply #35 on: July 22, 2025, 20:29:34 »
For all of you who made suggestions and provided encouragement: a big thank you!
A new gas cap the locks and unlocks!
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #36 on: July 22, 2025, 21:48:30 »
Excellent news!
Ok, do not be difficult...
How did they remove the cap?
lreppond
« Reply #37 on: July 23, 2025, 03:28:24 »
Excellent news!
They removed it with a screw driver and a hammer!  According to my mechanic “all it took was a couple of good whacks!” And they were able to back it off.  I didnt ask for any further explanation.  Wish me luck with the new cap.
Even though I was unable to remove it, I truly appreciate the generous advice you provided.  You’re a true asset to this forum.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #38 on: July 23, 2025, 06:35:40 »
So they have driven it off by turning the inner piece with a screwdriver and a hammer.
We now have a possible way forward here on the Forum.
Quite honestly, you need to be "fluent" in this kind of work to do it - to get it done and not scratch anything. Sometimes it is just better to give it to the mechanic who knows how to use a hammer. I would hesitate to do it myself probably.
Good you got it done!
AndrewB
  • United Kingdom, Channel Islands, Forest, Guernsey
« Reply #39 on: July 25, 2025, 12:08:10 »
Len, thanks for letting us know how they dealt with it. How did you get a new gas cap with the logo on it ? Those are like hen’s teeth to find
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
lreppond
« Reply #40 on: July 25, 2025, 16:11:07 »
Over the last couple of years I’ve bought 3 w/logos.  Why?  No clue but it has turned out to be convenient.  Two are the double sided key ways but I’ve yet to find anyone who can key them to my car.  I even have a box of HF wafers.  It’s just a matter of opening them up and accessing the tumbler.
Filled my tank this AM. So nice.  Going to the tire shop to get a new set of WW’s mounted.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #41 on: July 25, 2025, 19:58:36 »
Any preventive maintenance we could perform on our original caps to extend their life?
« Reply #42 on: July 25, 2025, 21:27:56 »
Good question, and I look forward to seeing the forthcoming answers.
To most folks, a gas cap is "screw it on and forget it" thing.  Our gas caps are a piece of automotive jewelry that likely would benefit from occasional care and  attention.
ejboyd5
  • Southold, NY
« Reply #43 on: July 26, 2025, 11:28:23 »
Did you perform a necropsy on the old cap to determine the removal problem?
yves
« Reply #44 on: July 26, 2025, 11:31:24 »
Was it the tab spring which have failed?
« Reply #45 on: July 26, 2025, 11:35:24 »
I should start a separate thread.
TJMart
  • USA, NC, Matthews
« Reply #46 on: July 26, 2025, 18:32:18 »
Len,
I have a guy that I believe can rekey your caps. PM me if interested
Tony
Tony
1970 280SL, 4 Speed
