Hello everyone
I recently had a 5-speed Getrag 265/6 gearbox and shortened drive shaft installed in my 1970 280SL (originally manual 4-speed).
I have now done a bit more than 1200 km with the gearbox and revised (shortened) drive train, and the gearbox runs and shift great - it’s like having another car, when driving at an elevated speed at now much lower RPMs.
However, I have recently noticed a vibration issue that slowly have become worse and worse, and it seems to originate from the drive train rather than the gearbox, when accelerating at high torque, thus especially in 2nd gear. But the deep vibrations from the rear, which can be felt in the chassis, can also be felt in 1st and 3rd gear, but are most pronounced when accelerating hard from stand-still going through 2nd.
I can almost avoid the vibrations, if I accelerate more smoothly and I don’t push/torque the car. But if I accelerate harder the vibrations are there again. But they can only be felt when accellerating from stand-still - not at higher speeds in 4th and 5th gear.
Just for the record: As part of the installation of the 5-speed Getrag, the special shortened front drive shaft was welded to a BMW star-fitting to match the Getrag 265/6 originating from a BMW, and then balanced together with the rear drive shaft at a drive shaft workshop. Also, a new BMW rubber flex-disc was installed. Likewise, the center drive shaft bearing and rubber housing was renewed too and the cross link bearing at the rear axle end was also replaced, before balancing of the drive shaft.
In the beginning the vibrations were not noticeable, but they have become increasingly apparent over the past 4-500 km.
Any clues what I am facing here?
Christian
