Author Topic: Thermo-Time Switch 001 545 15 24 $299-Only 1 left  (Read 753 times)
slschock
  • USA, CA, Poway
« on: July 02, 2025, 18:42:52 »
OEM VDO 001 545 15 24 Thermo-Time switches, which were also used on many early 60's mechanical fuel injection engine models, have been long since discontinued and are just about impossible to find, either new or used.  These are brand new original parts, never installed, not used. All are NOS (New Old Stock). VDO manufactured these for Daimler-Benz.  I am the founder and former owner of EUROPARTS of San Diego, which I owned and operated for 37 years before selling the business and retiring in November 2022.  Most of my old inventory is long gone but, I still have a few items left in addition to these thermo-Time switches.  I have listed specifications for both the 001 545 15 24 and 001 545 92 24 below.  These are listed to have been used on the 220SE & 220SEb (M127) and 300SE (M189) so, they can also be used on any of the W113 vehicles.  They are dimensionally identical to each other. The only difference that I see is the duration time of actuation.  I found info online that these two switches are interchangeable. I have only three of these Shipping to any US zip code is $15 and $53 outside the US.  A tracking number will be provided at time of shipment.  Only one left, as of 8/5/25.
SPECIFICATIONS FOR THIS SWITCH 001 545 15 24:
VDO 36/2/10
12V 40W operating voltage and wattage.
120 Deg C Max. operating temperature.
5 Deg C +- 3 Deg C. Temperature at which contact opens.
20 Deg C - 12 Sek 20 deg actuation time in seconds.
Terminals are stamped G & W  (Ground & Neutral)
SPECIFICATIONS FOR 001 545 92 24:
VDO 36/2/9 or 36/2/13
20 Deg C - 9.5 Sek 20 deg actuation time in seconds.
« Last Edit: August 05, 2025, 22:39:47 by slschock »
chris recker
  • USA, TX, North Richland Hills
Re: Thermo-Time Switch 001 545 15 24 $299-Only 1 left
« Reply #1 on: August 07, 2025, 20:47:44 »
DO YOU STILL HAVE ONE OF THESE SWITCHES LEFT ?
CHRIS@ADVANTAGEAUTOWORKS.COM
817-773-1852
LOOKING FOR 0015459224 , BUT WILL USE THIS IF IT WILL WORK
slschock
  • USA, CA, Poway
« Reply #2 on: August 07, 2025, 21:31:24 »
Chris
I have one of the 15 24's left and also one of the 92 24's left, as well.
If you want the 92 24, send $314 via PayPal to slschock@gmail.com
and I will mail it out.
Steve
