Author Topic: Slack in steering wheel  (Read 1301 times)
georgem
« on: June 25, 2025, 03:02:09 »
Lately I have noticed a bit more slack in the steering wheel - thought that the steering box might need adjusting (non power steering).
Anyway, today it seemed worse and I started to hear/feel a metallic clunk every time I turned the wheel.  A quick look showed that most of the slack was coming from the steering connector - the fitting on the shaft just up from the box.
The three studs which join the two halves are loose in the holes  - I assume they had rubber bushes at one time. Is this repairable or a throw away item?
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
cfm65@me.com
  • Cape Town, South Africa
Re: Slack in steering wheel
« Reply #1 on: June 25, 2025, 15:04:47 »
Hi George,
This is probably where your problem lies. This steering universal has built in rubber sleeves which smoothens the “universal” effect and ensuring a smooth operation of the steering wheel.
You local MB dealer should be able to assist.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
georgem
« Reply #2 on: June 25, 2025, 20:08:58 »
Hi Chris
Tks for the reply. I figured that was the problem - I guess I was asking can the two studs (I thought there were three)  that join the the two halves together be repaired with new rubber bushes - Niemoller  sell what looks like a bushing for the coupling - " D46059 Bushing Steering Coupling" - but I wasn`t sure. Easier to buy the whole coupling as you identify?
George McDonald
Brisbane
230 Sl
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #3 on: June 25, 2025, 22:09:59 »
Pictures,  The hard part is indexing the shaft so the turn signals cancel.    I failed at that part... The bushings were less than $10.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
georgem
« Reply #4 on: June 25, 2025, 22:54:34 »
Brad
Fantastic photos thanks. I have a feeling that a PO has done this once before because it looks (I haven`t taken it out yet) that the two studs are around the wrong way - maybe its a marvel that it lasted so long. Anyway, time to get it out and have a proper look as the repair or replace options are available.
BTW - this should be in the Manual -the pictures are so self explanatory.
Thanks again
George McDonald
Brisbane
230 Sl
« Reply #5 on: June 26, 2025, 02:18:44 »
Yes, pics good enough for the Rech Manual.  I had forgotten about the cotter pins.
