Author Topic: Dark Green soft top…  (Read 3719 times)
eb@bluwil.com
  • USA, NY, Sands point
« on: June 18, 2025, 17:19:17 »
So this is a bit of a call for help with a correct original soft top in Green. I’m not sure of how many of us know what color the liner is supposed to be on the underside/ inside of our soft top but all the details matter for crazy people like me! So the answer for green is a cream beige NOT BLACK. Unfortunately I’m told after extensive research that green top material in no longer available with the Beige underside.
1. does anyone know where I can find one; I would pay beyond top dollar for it or someone who has original material or an NOS green top…
2. Is any one else looking for one as I have spoken to several of the canvas top manufacturers and I have been told that green/beige material has not been made since the 70’s and because all the English cars that use Green soft tops (much more than German cars) need Green/black. If I want to have a run made they want a commitment to 800sq meters that’s a lot of tops…..
If anyone has a better idea or knows someone willing to sell I’m your guy…..
Thank you
Eric
Jack the Knife
  • USA, FL, Vero Beach
Re: Dark Green soft top…
« Reply #1 on: June 18, 2025, 18:34:17 »
Which upholstery suppliers have you contacted already?
Also this should be in the upholstery section.
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
« Reply #2 on: June 19, 2025, 04:21:36 »
Try Cabrio.de they will have the green but not sure about the pale interior as origional.
However you coukd ask it you can get one from them as a special order. They are very helpful.
https://cabrio.de/en/Softtop-Mercedes-Benz-230-280-SL-W113-including-tension-belts/VEDB113.SOFR
« Last Edit: June 22, 2025, 00:10:47 by Garry »
GM
  • USA, CO, Boulder
« Reply #3 on: June 19, 2025, 14:31:15 »
This is who I used. It was perfect. I have no relationship or interests in the company.
https://www.germanautotops.com/product/mercedes-benz-w113-230sl-250sl-280sl-63-71-black-german-w-plastic-window/
•First Quality German Sonnenland® Cloth / Canvas with a dobby weave lining
•Precision cutting with automated computer guided equipment
•The entire top is cut from the same bolt of cloth for consistent color & pattern
•Stitched with matching colors using the finest bonded polyester threads
•DOT approved heavy .040 gauge sewn-in, tinted plastic window
•Factory style hand rolled bindings
•Deck seams are heat sealed as original without tape
•Window areas are reinforced on the inside for added durability
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #4 on: June 21, 2025, 13:44:35 »
I did my tip a few years ago wanted to do a dark red wine color too and also wanted to have a tan headliner. At that time there was no one that had the dark red top with tan headliner, only black headliner. Found the Hursh located in New York did tops for high end Rolls Royce. They found me top material in Germany. You might try them to source out you top material. And yes I did pay a lot higher price for that material.
Robert Hyatt
Williamsburg, VA.
« Reply #5 on: June 22, 2025, 04:49:32 »
We have a separate upholstery section?
« Last Edit: June 22, 2025, 04:55:48 by rwmastel »
doitwright
  • USA, IL, Willowbrook
« Reply #6 on: June 29, 2025, 05:55:38 »
If you order from German Auto Tops you will be getting it supplied through GAHH. I believe they both got their tops from Robbins.
Frank Koronkiewicz
Willowbrook, Illinois
Jack the Knife
« Reply #7 on: June 29, 2025, 14:12:53 »
I meant cosmetics, interior, etc. this was posted in the full member board or something at first.
Seconding cabrio.de, I was very happy doing business with them. Very thorough.
eb@bluwil.com
« Reply #8 on: July 06, 2025, 15:41:49 »
I just reached out to your recommendation and hope to hear back.
Thank you,
Eric
