Author Topic: Auto Transmission won't shift into park  (Read 997 times)
ronwall83
  • USA, NE, Kearney
« on: June 17, 2025, 14:15:27 »
'66 230sl
The auto transmission will not shift into park.  It shifts just fine N --> R, N -- > 4,3,2, etc.  But, when trying to shift into park the shift linkage slips off the range selector knob mounted on the side of the transmission.  The linkage lever bushings are new.  I've checked the linkages at the "0" or "N" setting and everything is set.  The car runs and drives well, I just cannot park it in "P" position.  I have to park in Neutral, use E Brake and wheel chocks for good measure.
Everything I've read suggests linkage adjustment, but nothing appears bent or out of adjustment.  Thoughts?
RW
'66 230sl
ctaylor738
  • USA, VA, Falls Church
Re: Auto Transmission won't shift into park
« Reply #1 on: June 21, 2025, 11:37:42 »
Is the lever hitting the transmission mount plate?  This happens as the engine mounts and transmission mounts age and sag.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
