Author Topic: LED Flasher  (Read 3049 times)
Jack the Knife
  • USA, FL, Vero Beach
LED Flasher
« on: June 07, 2025, 17:43:37 »
Hey all,
Nearing completion of my car, finally...
Attached I have a photo of an LED flasher, which I have connected spades to so it can go into the OEM outlet. Does anyone know the order in which these spades go?
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
BobH
Re: LED Flasher
« Reply #1 on: June 07, 2025, 18:02:50 »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Jack the Knife
Re: LED Flasher
« Reply #2 on: June 07, 2025, 18:08:19 »
Everything you need on here:
https://www.sl113.org/forums/index.php?topic=30927.0
I wish I had Chris' connector, since his is labeled. His is a '9624,' where mine is an '8624' with no numbers on the plug-in side.
BobH
Re: LED Flasher
« Reply #3 on: June 07, 2025, 18:18:54 »
Ah, so:
Wire colours in the plug:
brown - to your new black
black/white/green - to your new blue
black/red/green - to your new red
UK delivered RHD
Blue soft top
Blue leather
Jack the Knife
Re: LED Flasher
« Reply #4 on: June 07, 2025, 18:29:55 »
Maybe ChatGPT of all things has solved the mystery, though I'd still appreciate an expert's opinion...
There are three prongs on the original Hella flasher relay - one is marked with 31, and one is marked with 54. It says, "31 and 54 are terminal designations based on the DIN 72552 standard," and that specifically:
31: This designates the return line to battery negative or ground.
54: This terminal is for the trailer plug connections and lighting combinations, including the brake light.
In summary, on a Hella flasher relay, terminal 31 is the ground connection, and terminal 54 is an output used for trailer lighting and brake lights.
So...
Blue wire: light, or 54
Red wire: positive, or 15 (on some other flashers, not on mine).
Black wire: negative, or 31.
Hope it's right!
Ah, so:
Ah, many thanks!
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: LED Flasher
« Reply #5 on: June 08, 2025, 12:45:21 »
This last post with picture should go into manual.
Robert Hyatt
Williamsburg, VA.
BobH
Re: LED Flasher
« Reply #6 on: June 08, 2025, 13:47:35 »
Added to the manual
UK delivered RHD
Blue soft top
Blue leather
