Author Topic: Cigar/cigarette lighter not working  (Read 2445 times)
Merc_Girl
« on: May 26, 2025, 16:49:23 »
Hi folks
Has anyone repaired or had experience of repairing their cigar/cigarette lighter by any chance?
I’ve had the ‘holder’ tested and that’s all fine, but for some reason the element of the lighter  doesn’t heat up?
I know new ones are available, but a Bessie is an early 230sl, I like the more ‘delicate’ push button, and these appear not to be available.
Any thoughts on what to do would be greatly received 🥰
230SL
WRe
Re: Cigar/cigarette lighter not working
« Reply #1 on: May 26, 2025, 17:41:23 »
Sometimes it's possible to change/unscrew the glow filament which is standard for a lot of lighters.
...WRe
Merc_Girl
« Reply #3 on: May 26, 2025, 21:02:14 »
Brilliant
Thank you all. 🥰
Must admit I’m not sure mine has one of those, I only see a coil of ‘spring’. Maybe that’s why it doesn’t work! 😱
Might someone have a picture of what the lighter should look like so I can compare?
Many thanks again
Katie
I’ll investigate
230SL
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #4 on: May 26, 2025, 22:28:59 »
When you push it in, you'll have access to unscrew the coil.
Lori
1968 280SL (US)
Merc_Girl
« Reply #5 on: May 29, 2025, 18:22:09 »
Thank you
Had a look and Bessie’s was loose and a little rusty. Going to try and clean it up and screw in tightly to see if that works
Fascinating, I never knew the little heating element came off! 😝
230SL
Merc_Girl
« Reply #6 on: May 31, 2025, 12:18:19 »
With thanks to all kind folks who replied.
Lighter now fixed!!!
Got my ever faithfull Dremel out and cleaned up all connections as there was quite a lot of corrosion. Heater element screwed down securely, now all working 😎
230SL
