Author Topic: drivers window door guides  (Read 2490 times)
NZ230
  • New Zealand, Canterbury, Christchurch
« on: May 24, 2025, 07:48:02 »
Hi does anyone have these for sale? Took the door card off and there arent any there!
Re: drivers window door guides
« Reply #1 on: May 24, 2025, 11:17:09 »
Is the car LHD or RHD?
You mean the actual steel guide rails or the aluminium covers?
NZ230
« Reply #2 on: May 25, 2025, 06:34:39 »
RHD
the things that glue onto the glass
what are they called?
« Reply #3 on: May 25, 2025, 06:45:51 »
We call them glass jaws or guide jaws. Not difficult to find and buy (someone may have it here, Mercedes, SLS, Niemoeller).
The important part is their installation. You are a Full Member - please visit Technical Manual and check the instruction for guide jaws installation. You may need several other items, plastic inserts, orange shims (replacements are black), set screws to do the job.
« Last Edit: May 25, 2025, 06:53:43 by Pawel66 »
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #4 on: May 25, 2025, 12:34:47 »
Did you check inside the bottom of the door?  I found mine in there.
Lori
1968 280SL (US)
NZ230
« Reply #5 on: May 26, 2025, 09:38:08 »
Thanks all. I will source from niemoller. Checked the bottom and not there. Not sure what is going on???
« Reply #6 on: May 30, 2025, 02:38:23 »
There are two different ones.
big one fits to the back and small one fits to front.
Which one are you looking for?
Walter
1967 220SL diesel getting a restored hardtop
1969 280SE
2003 Beetle TDI
2005 Honda Element
« Reply #7 on: May 30, 2025, 15:39:45 »
Nothing particular. They just fall off. It takes some effort to put them back on. Someone could put them aside for later fixing...
« Reply #8 on: May 30, 2025, 21:36:48 »
Also they could be stuck at the bottom of the window channel inside the door.
Bit of felt cloth and glue to put them back on.
Walter
1967 220SL diesel-hardtop being restored
1969 280SE
2003 Beetle TDI
2005 Honda Element
