Author Topic: Trunk water leaks  (Read 4706 times)
mauro12
  • Italy, Sicily, Messina
Trunk water leaks
« on: May 06, 2025, 20:59:18 »
Hello guys , I’ve noticed that every time I wash my car,  I see some water entering inside  the trunk . This happen only in the left part of the trunk . I attach some pictures.
I’ve replaced the trunk seal and even if it’s an aftermarket, it seems to be in good condition and in the right orientation. Probably I have a bigger gap in the left top corner of the trunk compared to the left but this is only an assumption. Also I see some drops coming from from the wheel arch . I cannot trace from where it enters .
Any help is appreciated.
Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Jack the Knife
  • USA, FL, Vero Beach
Re: Trunk water leaks
« Reply #1 on: May 06, 2025, 21:34:49 »
The same has happened to me, in the same spot. Look at your boot lid carefully. It may be when someone was pushing the car at some point, that the lid became bent. That is what happened with my car.
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
mauro12
« Reply #2 on: May 06, 2025, 21:57:58 »
I wanted to attach some pictures but I believe they are too high in resolution. I will post as soon as I can .
Mauro Pisani
« Reply #3 on: May 06, 2025, 23:43:21 »
Another culprit can be the taillight seal.
mauro12
« Reply #4 on: May 08, 2025, 18:56:04 »
i don't think is the tailight seal but something related to the correct orientation of the trunk seal or the soft top compartment seal . I try to post some pictures if i can .
Mauro Pisani
mauro12
« Reply #5 on: May 08, 2025, 18:57:44 »
If you see the last picture , i was seeing water dripping from there . i don't know where that panel is connected . Can you also clarify if my trunk seal is orientated properly ? it is not an oem but an aftermaket.
Mauro Pisani
zak
  • USA, NJ, Bernardsville NJ USA
« Reply #6 on: May 08, 2025, 21:14:09 »
I had the same leak issue in that same back left corner of the trunk.
I was told that it is a common issue for many 113s.
I solved my issue by never driving in the rain and always parking the car in the garage.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
« Reply #7 on: May 08, 2025, 21:54:49 »
I have the same leak issue in that same back left corner of the trunk.
I am interested in a possible solution as I cannot control the weather when I go on a long trip.
707dieseldean
  • USA, CA, Santa Rosa
« Reply #8 on: May 08, 2025, 22:36:24 »
Back in the day at the bodyshop.....We would remove the spare tire and put someone with a flashlight in the trunk.  ;D :(  Close the lid and have some use a waterhose with a spray nozzle spray water in the air over the rear area.Do not spray the trunk directly, spray water in the air so it will come down like rain. Should be able to find the point of entry. Good Luck  ;)
69 280SL / Manual 4 speed
 904 - Lower Midnight Blue
 158 - Upper White/Grey
 145- Vellum Interior
« Reply #9 on: May 08, 2025, 23:17:03 »
Do you have an indentation or crease on your spare tire cover or the tire itself somewhere near the trunk hinge?  Try letting some air out of the spare tire.  Some sidewalls bulge out more than others and come in contact with the underside of the hinge when the trunk is locked.  This forces that corner of the trunk to lift, and it can lift clear of the trunk seal, letting in water.
If deflating the spare turns out to be the solution, make a point of carrying a tire pump.  One day you may find a need for a fully inflated spare!
LindesayOne
  • Canada, Alberta, Edmonton
    • LindesayOne
« Reply #10 on: May 09, 2025, 00:59:00 »
From my experience in identifying leaks in buildings, I would suggest isolating the leak by taping the entire gap at the perimeter of the lid, then removing the tape in small sections sequentially after spraying the entire lid. Each time a section of tape is removed, check the trunk for water.
Start removing sections of tape at a location least suspected to be the source of the leak.
John
1957 190SL 8500074 (RIP?)
1968 280SL 11304410006390 (RIP?)
1969 280SL 113044120011428 - Light Beige/Cognac
franjo_66
  • Australia, NSW, Point Piper
« Reply #11 on: May 09, 2025, 02:59:24 »
great tip !!
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
Paul & Dolly
  • i Car
« Reply #12 on: May 09, 2025, 07:42:22 »
Water can also leak into the soft top storage compartment, and subsequently drip into the boot or trunk via the hinge openings on the left and right sides.
Good luck
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
« Reply #13 on: May 09, 2025, 07:59:23 »
Your boot seal doesn't appear to be installed correctly. The lip should not be vertical, rather it should be beyond the vertical such that when the lid is closed against it the seal is folded over. Many a door or trunk lid has been difficult to close because of the excessive resistance offered by an incorrectly install rubber seal.
BobH
« Reply #14 on: May 09, 2025, 09:14:49 »
Some tips on here about fitting the seal correctly
https://www.sl113.org/forums/index.php?topic=14415
and on here, as Paul says, water can leak into the trunk/boot from the soft top compartment if the drainage routes are blocked
https://www.sl113.org/forums/index.php?topic=375.msg56932#msg56932
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
mauro12
« Reply #15 on: May 09, 2025, 18:30:34 »
The best solution is to put someone inside the trunk , that's really nice solution ! Do you have some pictures about the correct orientation of the seal ? i've seen all posts but there are different opinions . Have yu seen my last picture? i saw small drops of water coming from that panel . Is that connected to the soft top compartment ?
Mauro Pisani
LindesayOne
    • LindesayOne
« Reply #16 on: May 09, 2025, 18:35:24 »
Someone inside the trunk.   Yes, that's what little kids were made for!
John
John
Jack the Knife
« Reply #17 on: May 09, 2025, 19:13:38 »
Not to hijack the thread, but since I have a similar issue, I went out and took some pictures... I am having the leaking from the left side, as well. I have also noticed a slightly-off trunk alignment, which I can only guess happened either when someone was pushing the car incorrectly or when it was resprayed in its prior life. But Colin, does the seal look correctly-installed? It came this way, but I have an extra.
« Reply #18 on: May 09, 2025, 19:21:33 »
Perhaps an idea for both of you. If your emblems (230SL and could also be automatic) are not sealed properly, and they are on the left side, water gets to trunk lid frame and when you raise lid, it comes out through the opening I marked on Mauro's picture.
BobH
« Reply #19 on: May 09, 2025, 19:36:57 »
If you look at reply 5 on here, a diagram of the rubber profile, and the other pictures, you'll see a correctly fitted seal, Mauro and Jack, it's hard to tell from your pictures, but neither of your seals look to be correct, i may be wrong and it may just be the pictures
UK delivered RHD
Blue soft top
Blue leather
hbrand
  • Edgewater
« Reply #20 on: May 09, 2025, 20:59:29 »
Not using any seal might be better.
Then water runs along the sides just like a gutter.
Where the gasket is glued in had a rust hole so water entered the trunk there.
Greetings, Harold
« Reply #21 on: May 10, 2025, 08:28:23 »
This should be the correct positioning.
Jack the Knife
« Reply #22 on: May 10, 2025, 23:28:33 »
Thanks to the both of you, I just took the old seal out and put in the new one. It was much deflated. However, now my trunk lid is sitting a bit high, noticeably so. I believe someone did bend it out of shape at some time, for sure. Should be easy to rectify at a body shop, I guess.
