Author Topic: Fuel Vapor Outlet  (Read 1523 times)
jeblack123
  • USA, GA, Albany
Fuel Vapor Outlet
« on: May 05, 2025, 17:07:55 »
Good afternoon.
As I have been trying to eliminate the fuel smell in my trunk, I have replaced the 3 rubber tubes coming from the vapor tank and ordered the "funnel shaped thingy" that protrudes from the underside of the car between the fuel tank and the exhaust. I cannot locate the 6mm metal tube that is described that the funnel shaped thingy should attach to. Does anyone have a picture of this tube or even a rough description of the length and shape so that I may fabricate a replacement?
Thanks, in advance for any help.
Sincerely,
James (Eddie) Black
Re: Fuel Vapor Outlet
« Reply #1 on: May 05, 2025, 17:50:40 »
This is what I could find from my restauration project 280SL April 1969.
Diameter 6mm, length I estimate between 60 and 70 cm.
BobH
« Reply #2 on: May 05, 2025, 18:19:40 »
There are some pictures on here, until it disappears into the filler neck cover
https://www.sl113.org/wiki/Originality/1967230SL
and reply #542 on here
https://www.sl113.org/forums/index.php?topic=21397.msg204546#msg204546
« Last Edit: May 05, 2025, 18:38:54 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #3 on: May 09, 2025, 15:16:15 »
Did you check the fuel sending unit seal?
two small hoses from the fuel tank filler neck?
No mention of those.
Walter
1967 220SL diesel
1969 280SE
2003 Beetle TDI
2005 Honda Element
jeblack123
  • USA, GA, Albany
« Reply #4 on: May 09, 2025, 16:15:58 »
Thank you all for the replies and advice. I located the vent tubing; it was bent more towards the fuel tank. I will check the fuel sending seals next.
Eddie
