Author Topic: Getting ready to install the wood bow  (Read 2404 times)
CJHenderson
  • USA, AR, Benton
« on: May 02, 2025, 22:39:36 »
Getting ready to install the wood bow. The question that I have, is it better to install the windshield or the bow first?
1950 MG-TD
707dieseldean
  • USA, CA, Santa Rosa
Re: Getting ready to install the wood bow
« Reply #1 on: May 02, 2025, 22:47:58 »
Install the wood first. Less chance of damage to dash upholstery with the studs from the wood bows. If you decide to install windshield first, slid a small piece of hose over the stud to pervent damage to dash. Remember "Patience is a virtue"
69 280SL / Manual 4 speed
 904 - Lower Midnight Blue
 158 - Upper White/Grey
 145- Vellum Interior
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #2 on: May 05, 2025, 12:39:38 »
I agree 100%.  If installed after windshield install, protect the dash, I used cardboard and spare leather scraps.
Robert Hyatt
Williamsburg, VA.
CJHenderson
  • USA, AR, Benton
« Reply #3 on: May 05, 2025, 18:51:49 »
Thanks, guys, for your input.
1950 MG-TD
« Reply #4 on: May 06, 2025, 08:16:12 »
The driver's side was a challenge with windshield in. Do not forget the little aligning pad between the bows. Helps a lot...
CJHenderson
  • USA, AR, Benton
« Reply #5 on: May 07, 2025, 16:02:14 »
Are you referring to the three spacers that was between the bow and top of dash?
1950 MG-TD
« Reply #6 on: May 07, 2025, 17:12:03 »
To the little flat plate between the bows, the one in the middle.
zoegrlh
« Reply #7 on: May 10, 2025, 20:15:03 »
If you don’t have the spacer, you can make it out of felt material
Robert Hyatt
Williamsburg, VA.
