Author Topic: Mercedes Benz 220SE m127 engine for sale  (Read 4485 times)
Hamid Turbo
  • USA, CA, Los Angeles, Los Angeles
« on: March 18, 2025, 18:45:37 »
I have a complete 1961-1965 Mercedes Benz w111 220SE coupe/cabriolet m127.984 engine for sale.
Removed from a running car.
$3000
« Last Edit: July 28, 2025, 04:08:21 by Hamid Turbo »
1970 280SL Signal Red
1964 220SEb Coupe W111 White
1973 VW beetle 2.7L Bronze Metallic
2021 Dodge Charger SP WB Tor Red
2018 Dodge Charger SXT Maximum Steel Metallic
Re: Mercedes Benz 220SE m127 engine for sale
« Reply #1 on: March 19, 2025, 04:05:13 »
Pictures? Numbers on the motor data plate? Also need a description of its condition.
Hamid Turbo
« Reply #2 on: March 19, 2025, 06:06:28 »
The number on the engine is;
127 984 10 011 621
It was removed from a running car years ago.
It might need to service the injection pump but internal of the engine is perfect.
« Last Edit: April 09, 2025, 18:31:08 by Hamid Turbo »
opopotts
  • Canada, ON, Douglas Dees
« Reply #3 on: June 22, 2025, 23:30:59 »
 Can you crate that on a skid and ship on a truck to Canada? I have done that Canada to the US. It is about $600 US
opopotts
« Reply #4 on: June 25, 2025, 15:28:27 »
I am interested but How do you know what the internals are like? Did you remove the head and inspect the camshaft etc?
Doug
Hamid Turbo
« Reply #5 on: June 28, 2025, 23:14:03 »
Hi Doug,
sorry for late response,
i got this engine from a lady who her husband was passed away and he would collect classic cars and parts.
i just removed the head cylinder cover to see the camshaft which is fine. i can get a photo and send you if needed.
i just purchased an excellent 220se coupe and thinking to keep the engine but if you want it i will send you and if not i will remove the ad.
i am pretty sure this is a low mile engine but it may need to service injection pump,.
i am here to do anything to proof this is a good engine.
opopotts
« Reply #6 on: July 06, 2025, 02:05:31 »
I am just in the process of checking mine to see the condition of the head but I have low compression of 120 to 130 with the last cylinder at 150
opopotts
« Reply #7 on: July 12, 2025, 02:20:18 »
Can you send me a picture of the cylinder head. e are starting to work on the car.
Doug
Hamid Turbo
« Reply #8 on: July 12, 2025, 04:31:36 »
I will send you some photos tomorrow morning.
Hamid Turbo
« Reply #9 on: July 12, 2025, 18:15:10 »
Here is this cylinder head with fresh valves and guides etc.
They are the same design but go from 1960 to 1966 or so.
opopotts
« Reply #10 on: August 16, 2025, 02:53:09 »
My 220SE  car engine  is now being examined to see if the engine should be replaced. Sorry for the delay as my garage has not done a compression check
Doug
Hamid Turbo
« Reply #11 on: August 16, 2025, 06:52:16 »
my wish is your car will run as soon as possible no matter if it needs an engine or something else.
here i have spare engine and another head cylinder for use on any car.
my car has driven 57k miles only and i don't think i'll  need to replace engine anytime soon.
opopotts
« Reply #12 on: August 24, 2025, 18:10:41 »
My compression tested 155, 160, 152,152,160,175 but We have not checked the cylinder head. Do you have a spare cylinder head that has been refurbished ?
thanks
Doug
Hamid Turbo
« Reply #13 on: August 25, 2025, 00:16:42 »
cylinder head with fresh valves guides and etc. is ready to install.
Thinking to get $500 and i can ship.
opopotts
« Reply #14 on: September 05, 2025, 21:51:19 »
Going on holidays and will be back on the 23rd. I am interested
Doug
opopotts
« Reply #15 on: September 05, 2025, 22:39:54 »
Can you send me pictures of that cylinder head?
Doug
Hamid Turbo
« Reply #16 on: September 05, 2025, 22:54:28 »
I posted right here above.
opopotts
« Reply #17 on: September 06, 2025, 14:36:45 »
OK
Doug
opopotts
« Reply #18 on: September 06, 2025, 14:39:26 »
Can you find out the shipping to Toronto Canada via truck?
Doug
« Reply #19 on: September 08, 2025, 02:38:57 »
Just the cylinder head you should be able to send by normal carrier rather than truck freight? I once sent a cylinder head across Europe in a wooden box I made using the regular French postal service.
