Author Topic: Reverse band adjustment  (Read 3125 times)
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« on: March 02, 2025, 20:15:31 »
About 2 weeks ago, my car had a little shudder in reverse and then it gave out altogether.  Shifting tor reverse raised the rpm quite a bit and the car will not move when accelerator is pressed.  I found info in the tech manual on adjusting the reverse band bolt.  The 22mm nut loosened easily but I cannot get the 10mm bolt to move in either direction.  It seems someone has adjusted it before as the bolt is somewhat rounded.
Does this bolt seem to be out way too far and any suggestions that hopefully don't require draining the transmission fluid that I just recently changed.
Lori
1968 280SL (US)
Re: Reverse band adjustment
« Reply #1 on: March 03, 2025, 05:27:45 »
See if you can get a good 6 point box end wrench or a 6 point socket on it and try to loosen it first. Spray it down with penetrant be fore screwing it back it for adjustment. You probably do not have to take it all the way out.
« Reply #2 on: March 03, 2025, 09:40:23 »
In my experience you're going to need to rebuild the transmission.
« Reply #3 on: March 04, 2025, 05:28:17 »
"In my experience you're going to need to rebuild the transmission."  Possibly so Stick. Still good to check the easy and least expensive things first. If the adjustment doesn't work remove the transmission pan to see if you have any parts or debris in the pan.
Lori
  • 1968 280SL (US)
« Reply #4 on: March 07, 2025, 18:25:12 »
I drained the fluid and removed the pan and dipstick/fill tube.  No debris in the pan.  But the bolt will not move in either direction.  I am scheduling professional help to look at and probably remove the trans for rebuild.
Lori
1968 280SL (US)
Lori
  • 1968 280SL (US)
« Reply #5 on: April 25, 2025, 22:44:50 »
Pedro @Mobil.Werks (also a fellow pagoda group member) came over and got the reverse band bolt removed.  It had a lot of corrosion in the threads.  He found a replacement and installed it today and I am back in business!  NO REBUILD NEEDED - WHOO HOO!!
Lori
1968 280SL (US)
« Reply #6 on: April 25, 2025, 23:22:22 »
Best possible outcome!
BobH
« Reply #7 on: April 26, 2025, 07:30:07 »
That is really good news
I'm sure many automatic owners were hoping it wasn't too serious
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
TJMart
  • USA, NC, Matthews
« Reply #8 on: April 29, 2025, 20:13:06 »
Great News Lori!
Tony
1970 280SL, 4 Speed
