Author Topic: Short fuel pump only works when dry?  (Read 7158 times)
Mollox
  • United Kingdom, England, Tonbridge
« on: February 21, 2025, 15:38:20 »
New member here - and I hope you don't mind a 4 door W108 interloper asking questions. I've been reading the forum on and off for years but now need your help.
My father's 1972 280 SE (M130) hasn't run for a few years. The fuel pump stopped working so he pulled it off - it looked to be just a broken impeller tooth, back when impellers were hard to come by. In hindsight it was very dirty, tired and worn. Some life happened and suddenly it's 7 years later. Recently I got hiold of it, ultrasonically cleaned it and rebuilt it with the full VEP kit (inc impeller and armature) - great kit and very enjoyable to bring the old and dirty pump back to life with it. It spun up on the bench fine but critically i didn't flow test it....
I also bought a bunch of parts and spent several days refreshing various items, servicing it and getting it ready for a very nostalgic first start (he's had it 40 years...) in a very long time, in the hope of halting its recent decline. And that obviously didn't go well...
In short the pump will spin any time except when it's on the car and has fuel in it.  After mounting and when first trying it will work intermittently for a few tries then it won't work at all. I've measured 11.3 - 11.5v at the pump and also powered it directly with a spare battery. As soon as i take it off the car and drain whatever fuel is in it it will spin up again. I took it apart (again off the car) and tested each stage individually (dry!) - and all good. Right until it gets on the car and we try and start it, then it rapidly returns to doing nothing.
Am sure this must be a basic thing - can anyone point me in the right direction please?
The car is also in another country so i get to spend 2-3 days with it every 3 or 4 months so really want to get it fired up next time as getting so close was torture.
Thanks in advance
M
dirkbalter
  • USA, CA, Corona
Re: Short fuel pump only works when dry?
« Reply #1 on: February 21, 2025, 17:07:14 »
Welcome.
I have had the issue that the car (108) would randomly shut down and start back up due to the fuel pump not running (which I can hear running or not). As it turned out, it was the fuse connection in the box being oxidated.
That may not be your issue but is easy to check and eliminate.
Good luck.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BobH
« Reply #2 on: February 21, 2025, 18:03:50 »
Also, check that's it's not running in reverse, see this post, if the pump case is assembled incorrectly it will run, but fuel delivery will be low
https://www.sl113.org/forums/index.php?topic=38947.msg284521#msg284521
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Mollox
« Reply #3 on: February 21, 2025, 20:42:15 »
Hi
Thanks for the suggestions, but don't think it's these.
@dirkbalter I cleaned all fuse and fusebox connections but also put external power to the pump when mounted on the car to rule out power delivery. It wouldn't spin.
@BobH It's possible that its assembled incorrectly - I did follow the instructions/video carefully. I can't check until I'm next with the car but also we tested with the connections reversed adn no joy. Its not that its spinning the wrong way - it's just not spinning when it is on the car - so its either the fuel or the potential load. I replaced all fuel lines around the pump but can't speak for the main delivery/return pipes to/from the engine. If they were blocked then you'd think the pump would still be spinning or trying to spin? It's easy to hear when it does.
I have a question/theory. Is the top section (containing brushes and armature) meant to run dry? I'm guessing yes. Perhaps fuel is getting into there and stopping the pump from working?
All I have to do is disconnect the fuel lines and it will spin again!
BobH
« Reply #4 on: February 21, 2025, 21:27:21 »
Couple more suggestions:
Perhaps the impeller is on back to front, under load with fuel maybe it won't spin?
Perhaps the system needs priming, purging of air, see this post:
https://www.sl113.org/forums/index.php?topic=35193.msg257358#msg257358
Your "short" pump is designed to run wet, so fuel flows through the brushes and armature to cool it, don't run it for too long on the bench without fuel or it may overheat
UK delivered RHD
Blue soft top
Blue leather
Pinder
  • USA, NJ, Edison
« Reply #5 on: February 22, 2025, 12:48:57 »
Have you tried running it while mounted in the car but with the fuel lines disconnected? and if it works then connect the inlet fuel line and still see if it pumps (outlet line put into a gas can to catch the fuel.  Basically, try to see if the lines are not clogged.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Mollox
« Reply #6 on: February 23, 2025, 11:04:13 »
Thanks for the further suggestions.
Pinder - yes, I’d forgotten that I’d also removed the outlet hose from the pump and it still wouldn’t spin.
BobH - the VEP video was very clear on the thin part of the impeller vanes pointing back into the housing and I can remember double checking that. Unfortunately I won’t be with the car for a couple of months to triple check.
The purging/priming link was interesting thanks.
Re purging, for most of the time testing I had the hose to the fuel filter canister disconnected and feeding into a clear bottle as just wanted to prove fuel was reaching the engine bay. In all the faffing I saw two pulses and about a thimble full of fuel reach the bottle. But again the issue seemed to be a silent pump rather than clogged metal lines - and the test with no outlet hose on the pump should have mitigated clogged lines?
Re priming, I found the tank bone dry and so added 20 litres which is a smidge over 5 US gallons. Could that be it? I’m stuck on the logic here as if it spins dry but not “half dry” then how could adding more fuel fix that? Stranger things have happened though!
I’m also working on the assumption that the pump should spin constantly with the ignition on position 2 - and that’s my dad’s recollection of how it was. I’ve read posts about the pump priming for a second only and then resuming on cranking - anyhow, the pump didn’t spin or pump when cranking either.
Here’s the setup: I renewed all lines to/from the pump, replaced the tank screen/filter and also added an inline filter between tank and pump - and double checked filter direction!
Euro cars tee the return line to the tank back to the pump but have a feeling US cars don’t. That’s how it always was.
I also bought some swanky zinc screws for the bottom cover plate and eventually noticed they were quite a bit longer than the originals so swapped the dirty old ones back in wondering if the cover was clamping the impeller. I then backed off the old screws until the cover was leaking but it still wouldn’t spin.
Still confused! Unless it’s simply not enough fuel in the tank??
(Struggling to add a pic, trying without)
Mollox
« Reply #7 on: February 23, 2025, 11:35:27 »
Pic...I really liked those zinc screws….
« Last Edit: February 23, 2025, 11:49:18 by Mollox »
« Reply #8 on: February 23, 2025, 14:23:21 »
The in line filter could be preventing the pump from getting fuel. The pump has some suction but most of the fuel draw is from gravity. There is a good fuel tank screen and then a very fine filter in the engine bay. That system is more than adequate for filtration. The added filter is not needed and possibly your problem.
Pinder
  • USA, NJ, Edison
« Reply #9 on: February 23, 2025, 15:13:24 »
there is supposed to be another filter on the inlet of the fuel pump. (from what I can remember).
Kevkeller
  • USA, HI, Honolulu
« Reply #10 on: February 23, 2025, 20:25:10 »
Measure the voltage at the pump while it’s installed and trying to run. It almost sounds like you have a high resistance somewhere along the wiring that allows it to run without gas in it but as soon as a load starts it’s not enough current to keep it running.
1970 280 SL
« Reply #11 on: February 23, 2025, 21:01:18 »
Any idea may be good here...
You mentioned fairly low voltage on the pump in the car. It is likely, as Kevkeller says, it goes even lower under load and there is simply not enough juice...
Does it work in the car when you power it separately from 12V source (not a weak battery)?
I am not sure where the wires on the picture are coming from... Is it the correct arrangement for 230SL?
Also (it is not the reason for pump not running) you probably should not be using the T connector for return in 230SL if you did not replace the return fitting.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #12 on: February 24, 2025, 01:57:50 »
Undo the bleeder screw fully have someone else turn the key to  position 1 you should have the gas come with some pressure out of the bleeder.
Also keep in mind running the pump while dry will cause it to heat up very quickly and melt glue holding armature together.
Baronyoungman@hotmail.com
Bob "Baron" Youngman
1965 220se coupe restomod
Mollox
« Reply #13 on: February 25, 2025, 13:30:36 »
Thanks again for the ideas guys - I can't see how to multi quote so will reply to each individually.
I like this one. There really isn't much of a height difference between the tank outlet and the pump inlet and the filter does seem to be raising the centre of the feed pipe a little. Also only 20l/5 gallons in the tank.  And of course it is a significant change from the proven original setup. Tank screen filter was replaced with new and the filter in the pump inlet is glistening as it was ultrasonically cleaned but the tank had sat dry for several years so I added the inline filter as a temporary measure to protect the refurbished pump just in case there was any residue in the tank around the first starts. Ironically I endoscoped the tank and it looked much better than i feared.
The bit I can't resolve in my head is - if it spins when dry but not when say "half filled", why would it spin if fully filled. Unless there's some vacuum/gravity magic at play...
Also really frustrating that the car is in another country as it would take me 5 mins to whip out the filtered line and replace with a straight line and test.
« Last Edit: February 25, 2025, 13:39:20 by Mollox »
Mollox
« Reply #14 on: February 25, 2025, 13:32:29 »
I did a couple of times and got 11.5 and 11.3v. Insofar as "trying to run" it just wasn't making a sound at all so can't say if it was "trying", it just wasn't.
Mollox
« Reply #15 on: February 25, 2025, 13:34:31 »
Thanks Pawel.To test  I also powered it directly from wires from a new Bosch 12v battery whilst on the car - and it wouldn't spin either. The wires on this car seem to come from above or beside the fuel tank but its a W108 280SE M130 not a 230SL. Same for the T connector on the return line - that's how its been for the 40+ years he's had it and it was always fine.
Mollox
« Reply #16 on: February 25, 2025, 13:38:21 »
Thanks Bob. It's a euro car so the bleeder isn't tapped, its connected to the return line via a Tee as shown in the pic above. I can't remember why we're (you're!) different - seem to recall its evap regs. If you think it would help, I could block off that return line and test with the bleeder open. In 2 months time when I'm with it...
Re testing, I never spun it dry for more than a second at a time and really not that much.
ps that's a nice-looking pump, is it for sale?!  :-\
BobH
« Reply #17 on: February 25, 2025, 13:40:42 »
It doesn't appear to be an electrical problem, don't forget the suggestion by Bob (BaronYoungman), he's the undisputed expert on these pumps
Why not prepare to run the pump off of the car with fuel, if that works then it has to be something on the car, blocked pipes, air in the system or the position of the pump and filter
UK delivered RHD
Blue soft top
Blue leather
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #18 on: April 17, 2025, 12:48:54 »
I know from a PM you sent you are working on this now. I have another idea, the valve on top of the pump is a one way valve it allows the gas to go toward the engine but does not allow it to flow back. Hence you don't need to prime your fuel system every time you start the car. I have seen these get totally clogged and not open, in that case the pump will run but no gas flow. This valve is removed with a 22mm wrench ( spanner for you Brits) once off and don't lose the crush washer below it, you can check it by blowing through it, you should hear the flap open and air pass through.
« Last Edit: April 17, 2025, 12:59:50 by BaronYoungman »
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #19 on: April 17, 2025, 12:57:41 »
This valve
Mollox
« Reply #20 on: April 17, 2025, 13:32:16 »
Hi bob, you’re here there and everywhere!
That looks like the fitting on the pump outlet? It was ultrasonically cleaned and looked really nice. Per our convo I think I need to flow test the pump off the car. Will test the valve too, thanks.
I will say that last time I didn’t blow any of the metal fuel lines under the car as didn’t have a compressor. Now have a shiny new one so will be blowing every pipe in sight. Based on the state of a coolant line I just cleaned, this is probably a good idea.
Mollox
« Reply #21 on: April 17, 2025, 13:37:03 »
Just to add the pump won’t run at all when it’s on the car with fuel in it. But always runs when I take it off.
Mollox
« Reply #22 on: April 17, 2025, 20:30:11 »
Quick update (because I really really need a beer) the bottom of the new impeller is rubbing against the body of the pump. We have to loosen the cover past the point of fuel leaking out to get it to pump fuel.
Not sure what to do next (other than have a beer).
Mollox
« Reply #23 on: April 18, 2025, 16:37:19 »
Update…. Turns out beer is good for the brain. I remembered that we had a spare pump in bits, so tried the (original, heavy) impeller from that and the pump immediately pumped fuel on the bench, looking really rather normal.
And so the car just started for the first time in almost 8 years!
Took a bit of cranking and the ignoring of a fairly pronounced cold start valve leak but seems to be running surprisingly smoothly. Well, apart from  a significant exhaust leak, but we knew that.
Looking forward to discovering all the other things that are wrong with it - onward and downward!
Mollox
« Reply #24 on: April 18, 2025, 17:52:11 »
It ran up to temp really nicely. We let it cool down, have just started it again and the pump has stopped!  >:(
