Become a
Full Member
Emergency Contact List
Bushing Replacement for Manual Transmission Shifter Linkage
Topic: Bushing Replacement for Manual Transmission Shifter Linkage (Read 3090 times)
Mauricio P
Junior Level
USA, WA, Redmond
February 01, 2025, 23:06:33 »
All,
In the event this comes up for anyone, here are some details for replacing shifter linkage bushings for a 67 250SL, 4 speed.
Straight forward replacement and can be done from inside the car.
clunker
Full Member
Senior
USA, NJ, Chatham
1969 US 280SL 4-speed
Re: Bushing Replacement for Manual Transmission Shifter Linkage
February 02, 2025, 22:52:01 »
Thanks for this. Here is a PDF version of your document.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
twistedtree
Full Member
Gold
USA, VT
Reply #2 on:
February 04, 2025, 20:12:15 »
Shouldn't this just be put in the tech manual? Nice job, by the way.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
BobH
Full Member
Platinum
United Kingdom, England, MALDON
Reply #3 on:
February 04, 2025, 21:56:15 »
I added this to the manual the other day
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Dave
Junior Level
Canada, British Columbia, Vancouver
Reply #4 on:
May 08, 2025, 15:41:12 »
Hey, I’m new to the group chat. Would it be a bushing issue when the reverse gear is missing? I was driving and suddenly I could not find reverse and the stick shift was very loose and sloppy. There are no grinding noises in the transmission. All gear 1 to 4 are fine but sloppy and no reverse. Help.
BobH
Full Member
Platinum
Reply #5 on:
May 08, 2025, 15:57:43 »
Hello Dave, welcome to the group
It certainly sounds like the bushes are shot, have a look on the post below, same symptoms, and if you need any more tips, just use the search function above left, search for "shifter bushes", or just bushes, or just shifter
https://www.sl113.org/forums/index.php?topic=4951.msg30792#msg30792
UK delivered RHD
Blue soft top
Blue leather
