Author Topic: W113 Engine and Fuel delivery parts for sale. All used parts  (Read 3015 times)
Crobitaille1959
  • USA, CA, SAN CLEMENTE
All,
For sale below, Please PM me for pictures of any parts you are interested in. All were removed from a "Barn Find" 1969 280SL that I'm restoring with an engine swap. Engine and 4-speed transmission are already sold. All OEM parts I'm open to reasonable offers. You'll pay the freight actual cost.
Starter, tested and working $125 obo
Alternator, complete with mounting bracket and hardware $250 obo
Fuel Injection Pump, turns by hand $450 obo
Rear Exhaust manifold, no cracks, with all bolts $200 obo
Front exhaust manifold no cracks $200 obo
Intake Manifold, no cracks $400 obo
"Loop" brackets and bolts that attach to oil pan that secure Starter Cable and other electrical wires $50 obo
Fuel Injectors [6] $300 obo
Gas Filter housing $75 obo
Fuel Pressure regulator $75 obo
Distributor with all leads $350 obo
Water Pump [and bolts[ $100 obo
Motor mount [with OE Bolts, bottom section, R & L, $100 obo
Motor mount brackets that attach to Block [with bolts] OEM 1272231104 & 1272231204. $300 obo
Steering Wheel, Black [no cracks] with Chrome ring. Pad must be replaced, $200 obo
Complete throttle linkage assembly, all parts, pivots and brackets $400 obo
Thermostat housing $75 obo
Fuel Injection lines, complete $350 obo
Fan Pulley $75 obo
Crankshaft Pulley w/Balancer and all bolts $400 obo
Fan w/clutch $75 obo
Aluminum Heat shield, fair condition $100 obo
Thanks to all
BOTIGER1970
  • USA, NC, Mooresville
Re: W113 Engine and Fuel delivery parts for sale. All used parts
« Reply #1 on: February 01, 2025, 00:14:19 »
checking to see if the alternator is 55AMP or 35AMP.  Also since you are swapping your engine out, I wanted to check if you have a fan shroud that you are wanting to sell for a 280SL.
Mark
Crobitaille1959
« Reply #2 on: February 01, 2025, 23:22:42 »
35 Amp. Part number 0 120 400 606
