Author Topic: Capillary tube?  (Read 3246 times)
Capillary tube?
« on: December 28, 2024, 23:01:18 »
Hi.  I'm starting to take things off the cylinder head.  I'm (incredibly slowly) embarking on my engine rebuild.  Is this the delicate capillary tube in the video?   Any advice on removing this whole device?  Thanks.
https://youtube.com/shorts/R8VoZoqsTWQ?si=g0dnqlsP30uqVwjt
Re: Capillary tube?
« Reply #1 on: December 29, 2024, 03:34:36 »
Yes, that is the delicate capillary tube. It is somewhat protected by the braided sleeve. Unfastening the 14mm fitting is the correct way to remove it. However. you must make sure that the capillary line does not rotate with the 14mm fitting as you are turning it or you risk twisting and breaking the capillary tube. Use penetrant first then closely monitor the braided line while turning the fitting. An alternative is to unbolt the 15mm head bolt holding the whole pod assembly on the head. You can leave all wires and lines attached and simply set it aside for now.
Re: Capillary tube?
« Reply #2 on: December 30, 2024, 19:44:57 »
Thanks Joe!  I applied penetrant yesterday.  Will try the tube itself, and then the head bolt (yellow arrow) to remove the assembly.  This car has a long history of old bolts coming off properly.  It looks like the whole assembly needs about a 30mm wrench (orange arrow) to unscrew the assembly out of the head.  Is that right?
MikeSimon
  • USA, OH, North Royalton
Re: Capillary tube?
« Reply #3 on: December 30, 2024, 21:55:53 »
I believe the pot comes off the head with the small bolt, not the large 32mm nut.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: Capillary tube?
« Reply #4 on: December 30, 2024, 22:25:52 »
Thanks Mike.  I measured 33mm off my adjustable wrench, I agree 32 is probably right.  It would need to be ground down skinny.  I got the bolt on the side loose.  Can't remove it due to interference from fuel pump.  It feels too short to reach into the head, we'll see.  After light cleaning, you can clearly see a seal or bushing by the head and a washer by the housing.  I'm thinking the housing needs removed turning this 32mm nut.  I'll look in the BBB.
Duncan200
Re: Capillary tube?
« Reply #5 on: December 30, 2024, 22:36:17 »
Rod,
The whole cooling block comes off with the smaller bolt you have highlighted in your pic.
From memory it’s a 17mm head.
Once you have that off, you can fit a socket over the fitting that goes in to the head.
Doug.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Re: Capillary tube?
« Reply #6 on: December 30, 2024, 23:52:43 »
Once you remove the 15mm bolt securing the pod to the head, here's what that fitting looks like (pic). There's an aluminum washer between the pod and the fitting.
« Last Edit: December 31, 2024, 00:03:17 by Charles 230SL »
Re: Capillary tube?
« Reply #7 on: December 31, 2024, 01:00:14 »
I saw a good exploded view diagram in my parts book.  How does the pod come off the fitting?
Re: Capillary tube?
« Reply #8 on: December 31, 2024, 05:56:02 »
The 15mm headed bolt holds it on. Just unfasten it and the whole pod will come off. Don't mess with the 32 mm fitting.
BobH
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Re: Capillary tube?
« Reply #10 on: December 31, 2024, 10:22:12 »
Here is how it looks like and what is required.
239 - seal ring, A 094 990 08 08, available at Mercedes, ca $7
235 - seal, A 127 203 02 80, available at Mercedes, ca $5
266 - seal,  A 094 990 83 07, available at Mercedes, ca $1
The part that looks like a meat grinder, the pod and bolt are NLA.
johnk
  • USA, OH, Avon
Re: Capillary tube?
« Reply #11 on: December 31, 2024, 12:39:24 »
I could not remove the 32mm fitting on mine no matter what I did.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Re: Capillary tube?
« Reply #12 on: December 31, 2024, 17:00:41 »
If you decide to remove the 32mm fitting #232 to have it plated. Be careful, I've seen the threads in the head come out with it !!! :(
MikeSimon
Re: Capillary tube?
« Reply #13 on: December 31, 2024, 18:53:37 »
I have several spare heads and removed this fitting from one of them when I cleaned it up. It was difficult, but it came off, fortunately without stripping threads.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
