Author Topic: Rear Axle mounting buffer kit help  (Read 2931 times)
Brandini
  • USA, WA, Seattle
« on: December 18, 2024, 01:15:10 »
I had a question regarding the rear axle mounting buffers. I am in the process of replacing mine but cant seem to figure out where the smaller rubber buffers go? What is the order to put them back in as I didn't have these smaller rubber buffers when I removed the original?
I ordered a kit from vintageeuro.com that came with the smaller ones but I noticed in the schematics (see 120) of other vendors that the smaller rubber buffers are not shown or offered.
Any help would be appreciated.
Brandon
« Last Edit: December 18, 2024, 14:51:50 by Brandini »
Brandon
1964 Mercedes 230SL
Seattle, WA
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
Lori
1968 280SL (US)
sens
  • Netherlands, North Brabant, Drunen
Re: Rear Axle mounting buffer kit help
« Reply #2 on: December 30, 2024, 19:20:08 »
Hello, the rubbers you mentioned are No 143 in the drawing.
They are positioned on both sides of the hole in the center of the picture.
Halvor Sens
Brandini
  • USA, WA, Seattle
« Reply #3 on: December 30, 2024, 19:30:09 »
Thank you! I was able to figure it out. Now just having a difficult time trying to put it all back together.
Brandon
1964 Mercedes 230SL
Seattle, WA
sens
« Reply #4 on: December 30, 2024, 19:33:07 »
I just did that job a few days ago, so if you have any questions...happy to help or take some pictures for you!!
Halvor Sens
Brandini
  • USA, WA, Seattle
« Reply #5 on: December 30, 2024, 19:36:45 »
Thank you - the new rubber buffers (no 143 on the drawing) are making it difficult to put the original bolt back in the middle. I can't seem to squeeze it tight enough for the bolt to catch. I was thinking of buying a longer bolt?
Brandon
1964 Mercedes 230SL
Seattle, WA
sens
« Reply #6 on: December 30, 2024, 19:42:01 »
I would not do that...
They should fit easily!
Is there a lot of tension that should be released by turning the axle (No 210) or can you align the rubbers easily in the middle?
Are the rubbers well orientated?
Halvor Sens
« Reply #7 on: December 30, 2024, 23:00:08 »
Perhaps on Brandini's car, since it was lacking those rubbers, a PO put in a shorter than stock bolt. So Halvor, if you can measure the length of yours, we can rule that one out.
DaveB
« Reply #8 on: December 31, 2024, 00:21:43 »
Original 250SE bolt total length very close to 45mm (can’t get access to measure exactly). And yes it does appear very short, there’s only one turn of thread protruding. Perhaps you can compress with a couple of clamps to start the bolt into the thread.
« Last Edit: December 31, 2024, 02:22:58 by DaveB »
DaveB
'65 US 230sl 4-speed, DB190
Brandini
  • USA, WA, Seattle
« Reply #9 on: December 31, 2024, 15:19:22 »
Thank you Dave for confirming. Yes, the bolt is very short and I can't seem to get it to thread. I've tried a clamp but access is very difficult - unfortunately I do not have a lift in my garage. I'll get it eventually!
Brandon
1964 Mercedes 230SL
Seattle, WA
sens
« Reply #10 on: December 31, 2024, 17:20:35 »
I would say the bolt is about 40 mm long.
Some pictures...
I have put my car on a few supports and the bolt is accessible.
« Last Edit: December 31, 2024, 17:31:36 by Sens »
Halvor Sens
