Author Topic: Disassembling rear axle to replace boot.  (Read 4369 times)
twistedtree
  • USA, VT
« on: December 08, 2024, 22:48:19 »
I have my axle assembly out of the car, and just want to double check the steps to disassemble it to replace the swing axle boot.  I think I need to:
- Remove the right axle shaft.
- Remove the compensator spring
- Remove the hinge pin and pull back the axle tube
- Then install the new boot while putting it all back together again.
Is that right?
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
Re: Disassembling rear axle to replace boot.
« Reply #1 on: December 09, 2024, 11:06:55 »
That's about it!
twistedtree
  • USA, VT
« Reply #2 on: December 09, 2024, 11:18:13 »
Thanks.
Is it not possible (or just a really bad idea) to leave the axle shaft installed, and separate both the axle shaft and axle tube from the pumpkin as one assembly?  The BBB says to pull the shaft, but sometimes it's written assuming you are doing a complete teardown rather than just a spot repair.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: December 09, 2024, 14:05:20 »
Years ago (many years while still in Germany) the MB dealer replaced the boot on my car and they used a split boot. No disassembly required. Still works.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
clunker
  • USA, NJ, Chatham
  • 1969 US 280SL 4-speed
« Reply #4 on: December 09, 2024, 14:33:01 »
To fit the full (not split) boot, the right axle shaft has to be removed and to remove that you need to remove the hinge pin.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
twistedtree
  • USA, VT
« Reply #5 on: December 09, 2024, 15:47:17 »
Just for clarity, there is the axle tube over which the boot fits.  Then inside the tube is the axle shaft that rotates and turns the wheel.
The hinge pin needs to be removed to remove the axle tube.  No doubt about that.   What I'm trying to understand is whether I need to first remove the axle shaft and then remove the tube.  Or can I leave the axle shaft and tube assembled, remove the hinge pin, and pull the axle shaft and tube off as an intact assembly.
Hopefully that's clearer.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
twistedtree
  • USA, VT
« Reply #6 on: December 09, 2024, 15:54:17 »
Correct.  There is a split boot available, but it's a nightmare to install, and still has a reasonable chance of leaking creating a second nightmare.  See this thread for my last experience going down that path.  https://www.sl113.org/forums/index.php?topic=31197.msg226360#msg226360
This time I decided to drop the rear end and disassemble to replace with a solid (non-split) boot.  It may end up just being a different nightmare than the last one - we will see.  But Stickandrudderman's comment stuck with me that taking the long route to fix it right is actually the short route in the long run.  So that's the way I'm going this time.  Stay tuned and we will see how it turns out.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
« Reply #7 on: December 09, 2024, 20:06:26 »
My experience with the split boot is very positive, but you need to use the right materials.
Order the split boot with the right clamps and use “Goop automotive” glue which is heat and oil resistant and stays flexible.
MikeSimon
« Reply #8 on: December 09, 2024, 22:14:14 »
As I said, mine was done by "Schneider Mercedes Benz" in Rüsselsheim in 1986. They most certainly did it the right way and I did have no nightmares to install it. ;D ;D 8)
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
twistedtree
  • USA, VT
« Reply #9 on: December 10, 2024, 19:48:52 »
And the answer is....... Yes, you can separate the right axle shaft and axle tube from the pumpkin as an intact assembly.  The whole thing pulls right off.  No need to disassemble the brakes, wheel hub, and pull the axle shaft separately.  Tomorrow I'll see if it goes back together as easily as it came apart..
Hopefully this will save others some work down the road.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
clunker
  • USA, NJ, Chatham
« Reply #10 on: December 10, 2024, 21:22:54 »
Thanks Peter - this is helpful information - the trade-off of full vs split boot is certainly improved by this saving in effort.
Charles
twistedtree
  • USA, VT
« Reply #11 on: December 10, 2024, 22:26:40 »
If replacing the boot was the ONLY repair that was needed, I might suffer through installing a split boot again.  In this instance I'm also replacing all the rubber bushings/buffers, shocks, and brake hoses.  So I'm tearing most of it apart either way.  It's just a question of whether I disconnect and replace things one at a time with the axle in place, or drop the axle and do it all on the floor in open space.  So far I think this was the right choice to drop the axle, and at that point it's a small extra job to separate the two halves and install a proper boot that you KNOW will not leak, vs the risk of leaks with a split boot..
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
« Reply #12 on: December 11, 2024, 13:45:39 »
I presume you will be installing a new pivot bush whilst you're at it? (1103501275) and will pay attention to the correct assembly details.
twistedtree
  • USA, VT
« Reply #13 on: December 11, 2024, 14:45:55 »
I have the BBB, so following that.  Any particular tips or cautions?  My parts are delayed a day, so I'm stalled for now.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
« Reply #14 on: December 12, 2024, 10:02:22 »
You need to find the tech details for installing that bush. I have a jig which I use.
