Author Topic: Emergency hazard switch - testing and fitting  (Read 8568 times)
Merc_Girl
  • United Kingdom, England, Godalming
« on: November 21, 2024, 14:25:35 »
Hi folks
Me again!?!?
So, I’ve recently purchased a period (I have an early Pagoda), what I would name as a ‘hazard warning switch’.
Slight flaw in my plan is that I don’t know how if it works or indeed how to wire it in, so only minor problems!?!?!?
So, to summarise, I’m calling out to all electrical pagoda gurus out there to :
a) advise how I can test to see if the system still works
b) how can I hard wire it in? (I’ve looked on the wiring diagram in the technical manual but couldn’t see a reference to hazard warning switch
As always, any advice greatly welcomed 🥰
230SL
WRe
Re: Emergency hazard switch - testing and fitting
« Reply #1 on: November 21, 2024, 15:01:17 »
Hi Katie,
your new hazard switch should have following terminals:
New        Old
15:   + ignition switch        (15 - black/red/green)
30:   + battery        (30 - red/blue/white)*
31:   - battery/ground        (31 - brown)
49a: flasher (exit, clocked)                                                              (54 - black/white/green)
R:     flashing light right        (R - black/green)*
L:     flashing light left        (L - black/white)*
The new switch/relay replaces the old flasher relay (wire colours may vary).
* flasher plug
BUT: Differences such as 230-250-280, US - Europe, manual transmission - automatic transmission, etc. can lead to differences in circuit diagrams, pin assignments and cable colours.
... Wolfgang
« Last Edit: November 21, 2024, 15:12:24 by WRe »
« Reply #2 on: November 21, 2024, 16:28:45 »
Katie, please post a picture with pin connectors numbers.
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #3 on: November 21, 2024, 16:33:26 »
Hi, Katie,
I, too, have a 230SL and have purchased one of these switches.  I've studied the wiring diagram and understand how they connect to the existing wiring.  However, building the wiring harness with the correct plugs is somewhat challenging, including sourcing the connectors.
I believe that our member Leonardo Peterssen (lpeterssen) has offered to make them (for a price, of course).  Just another option...
           - David
-David Pease
Merc_Girl
« Reply #4 on: November 21, 2024, 19:06:25 »
Will do David when it arrives! It’s in New York and I’m waiting him to drop off in December when he comes to visit 🥰
230SL
Merc_Girl
« Reply #5 on: November 21, 2024, 19:07:26 »
Hiya, presume could splice the wiring together ? 🥸
230SL
BobH
« Reply #6 on: November 21, 2024, 20:06:47 »
I'm not sure this old style hazard switch/blinker relay will work with LED's, unless you keep the existing blinker relay (i believe you recently fitted a new style electronic relay?) and use this hazard switch to switch the other relay.  Has anyone done this successfully?
So, having read more on this, seems the early hazard switches, which were supplied as an option, work alongside the original blinker relay, not instead of, so it will switch the old style relay, or a new relay if you've replaced it when fitting LED's
« Last Edit: November 21, 2024, 20:54:52 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #7 on: November 21, 2024, 21:29:51 »
I think David's idea to ask lPeterssen for help is a good one. You can probably ask him to make you a harness so that you will have it on a plug and play basis...
Also, as BobH says, if you have LEDs there it may not work. The older types of hazard switch relays were, sort of, taking over the blinking function form the regular blinker relay, generated their own blinking and sent to L and R blinkers. I think this blinking function was done the "load" way - if so, it may not work.
lpeterssen
  • USA, FL, Miami
« Reply #8 on: November 22, 2024, 11:37:54 »
Dear friends, David
That is right I have the special sub harness to connect those early style falsher/hazard relay available on my store.
Here the link:
https://wiredoktor.com/products/mb-w113-hazard-relay-sub-harness
Best regards
L.Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
Adjust blink speed
« Reply #9 on: November 22, 2024, 12:01:19 »
Katie:
You may add something like this on the output side of flasher /hazard relay.
See:
https://a.co/d/hP0mEtr
Best regards
L.peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
Sub harness for hazard relay
« Reply #10 on: November 22, 2024, 12:07:28 »
Here a photo of how the subharness looks so that you can install it without modifications to your main harness
Merc_Girl
« Reply #11 on: December 09, 2024, 22:37:01 »
Thanks everyone for your input
Apols for radio silence!
Mates arriving from US with said switch, so preparing for battle!
Well done for remembering I have LED lamps!?!?
I.have a ‘modern’ emergency flasher switch which was installed before I bought Bessie. Maybe I can bastardise that 😱🤣
230SL
Merc_Girl
« Reply #12 on: January 08, 2025, 16:30:23 »
Hi folks
So we’ve tried the switch but can’t get to work
Is there any notes anywhere on how I can test the switch itself to ensure it is fully functional, or how to refurb, to identify if it is the switch itself at fault or that the leds are causing the problem
Thanks again everyone 😁
230SL
« Reply #13 on: January 08, 2025, 16:44:20 »
Can you post picture of the connectors so that we see the numbers?
Jack the Knife
  • USA, FL, Vero Beach
« Reply #14 on: January 08, 2025, 17:50:44 »
Be sure to check fuses!
1964 230SL "Blue Note" -- #009785
2015 G550 "Milk Truck"
Merc_Girl
« Reply #15 on: January 08, 2025, 19:40:26 »
Here you go 😔
Ah, just spoken to ‘my man’ and he has confirmed the switch itself is faulty 😔
Does anyone in UK know a business who can repair such things (had enough of export forms and import duties!!!)🤬
230SL
« Reply #16 on: January 08, 2025, 21:12:51 »
Maybe then just to make sure:
- hook power to 30
- hook ground to 31
- hook bulb to L or R
- hook bulb to ground
Switch it on, it should be flashing.
The 54s are for regular blinkers, you may not need them. Your regular blinker will continue taking care of that.
This is how I wired mine. However, Leo is proposing more professional way of doing this.
As for repair, it may be as simple as cleaning the points or it may be very difficult to repair if not impossible.
Let’s see what Leo says, he is the Guru.
By the way: I am not sure if this switch is the one used in our cars. It has the K pin, which is for control lamp. But in our cars control lamps are hooked to blinkers on either side. We do not need the K pin. I think it would work anyway, it is just different type of switch.
« Last Edit: January 08, 2025, 21:44:52 by Pawel66 »
BobH
« Reply #17 on: January 08, 2025, 22:30:43 »
Here you go 😔
I wonder how your man tested it, in the car or on a bench?. As Pawel says you'd need to connect a filament lamp to L&R to make it work.  If they tried testing it in your car it won't work with your LED indicators, as they won't draw enough current to activate it
it will take a bit of figuring out to make it work with your modern indicator relay and LED's, it may need an additional standard relay or an additional indicator relay
I wonder if anyone else has tried this with success
UK delivered RHD
Blue soft top
Blue leather
gordon
  • United Kingdom, England, Burntwood
« Reply #18 on: January 10, 2025, 17:37:29 »
The one I bought was faulty. As a member of the UK Mercedes  club the technical guy (Jeremy Stevens) rebuilt mine with new parts and provided me with a schematic for me to make up the wiring all at a reasonable price
Merc_Girl
« Reply #19 on: January 10, 2025, 20:02:57 »
Great, thanks for the tip 🥰
230SL
WRe
« Reply #20 on: January 11, 2025, 08:34:00 »
HI Katie,
If I see it correctly, the contacts 54BL and 54S are used to make this emergency hazard switch/relay share the existing relay by interrupting the connection 54 (old notation) or 49a (new notation) to the flasher relay. Otherwise, if both relays were used at the same time, all flashing lights would light up permanently.
...Wolfgang
Merc_Girl
« Reply #21 on: January 12, 2025, 00:11:19 »
Thank you! 🥰
230SL
