Author Topic: Left front suspension list  (Read 3376 times)
cfm65@me.com
  • Cape Town, South Africa
« on: November 03, 2024, 14:24:29 »
Hi Guys,
The left front of my 250SL has sagged and unfortunately, I have not had a chance of putting it on a lift or over my pit, but maybe someone could give me a heads up on where to look.
The height of the fender arches from the ground are,
LF 61.8cm, RF 63.3cm
LR 62.8cm and RR 64cm.
It is quite obvious that something is amiss at the front left suspension.
Your inputs will be much appreciated.
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Re: Left front suspension list
« Reply #1 on: November 03, 2024, 14:56:50 »
Broken spring maybe? It happens, both rear springs on my 2001 Volvo failed, years apart.
« Reply #2 on: November 03, 2024, 17:56:20 »
It could be a broken spring, of course, but once you have it up on the stand:
1. Could be that someone (PO) replaced just one spring back in a day
2. Could be a heavy PO was driving alone for years
3. These springs have top and bottom - maybe someone installed one of the wrongly
4. Ride height is regulated by thickness of the upper spring pad. They came in various thickness (height) values (a couple of years ago I bought them from Mercedes). Maybe someone was not careful and installed two different ones?
Besides: I am not sure if I would be worried about 1cm difference, but that is just me, I am not an expert.
Duncan200
« Reply #3 on: November 03, 2024, 19:56:38 »
Hi Chris,
1.5cm is nothing to worry about. Even now when measuring ride heights for Wheel Alignment the tolerances are greater than that.
Given your in SA, I gather your car is RHD?
With most paired springs, one will be slightly higher and this one is fitted to the drivers side, at least that has been my experience in the automotive industry for over 30 years.
Obviously once you’re in the drivers seat the difference will be the other way.
Doug
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
cfm65@me.com
« Reply #4 on: November 04, 2024, 06:09:58 »
Thanks gents,
I have a LHD and replaced some springs a few years ago. However, as far as I can remember, it was the rear springs that I replaced.
I will report back, once I have it over the pit.
Much appreciated.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #5 on: January 06, 2025, 22:33:49 »
Chris,
Hi.  Not over the pit yet?
