Author Topic: Replacement Thermo-Time Switch Electrical Connections  (Read 3482 times)
Leester
  • USA, VA, Lorton
« on: October 26, 2024, 16:47:28 »
I bought the replacement TTS discussed in  https://www.sl113.org/forums/index.php?topic=26041.msg186571#msg186571  but discovered that the terminals are not marked (W for ground, G for 12V +).
The referenced post includes a chart with the the diagram shown.
Based on the configuration in the diagram I am going to connect the Pink/Blue wire to the terminal marked + on the diagram and the Pink wire to the other terminal. Knowing that improper connection will fry the TTS would greatly appreciate confirmation from a knowledgeable member that this is correct.
Another point for those using this replacement TTS; the connector needed is an EV1 and readily available, some with pins and pigtails installed. The Bosch part number referenced in the above discussion is a bare part with no pins or pigtails.
Many thanks to those who posted previously and hoping for quicker cold starts!
« Last Edit: October 26, 2024, 16:57:00 by Leester »
Lee Backus
1963 220SE Cabriolet
BobH
Re: Replacement Thermo-Time Switch Electrical Connections
« Reply #1 on: October 26, 2024, 17:28:27 »
Hello Lee, your connections are correct
Pink (W) -
Pink/Blue (G) +
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Leester
  • USA, VA, Lorton
« Reply #2 on: October 26, 2024, 20:06:44 »
Many thanks!
Lee Backus
