Author Topic: fuel pressure damper mount?  (Read 3093 times)
Brandini
  • USA, WA, Seattle
« on: September 08, 2024, 01:26:37 »
Does anyone know where I can purchase a fuel pressure damper mount?
My car doesn't have one which leaves the damper dangling. I've searched the forum and the internet but can't seem to locate one. Any help would be appreciated.
Brandon
1964 Mercedes 230SL
Seattle, WA
Re: fuel pressure damper mount?
« Reply #1 on: September 08, 2024, 03:02:42 »
I found our vendor list.  It's the "sticky" thread at the top of the vendor feedback board.
https://www.sl113.org/forums/index.php?board=21.0
Update:  That thread just has a post to the vendor list in the Tech Manual, but you're a full member so the link will work fine.
« Reply #2 on: September 08, 2024, 03:28:58 »
Only the early W113 cars had these since the mount was cast as part of the aluminum engine support on the later engines. I suspect that the early 220SE sedans of the era used the same mount. I'll check to see if I have any lying around!
Brandini
  • USA, WA, Seattle
« Reply #3 on: September 08, 2024, 16:13:09 »
Thanks for sending the vendor list, however, I've checked all the usual suspects such as buds benz, authentic classics, SLS, etc... I did find it on the Niemoeller website but doesn't look like it's in stock. Going to see if I can order it.
Brandon
1964 Mercedes 230SL
Seattle, WA
Brandini
  • USA, WA, Seattle
« Reply #4 on: September 08, 2024, 16:14:01 »
Thanks Joe I believe you are correct. If you do have one I would be most appreciative!
Brandon
1964 Mercedes 230SL
Seattle, WA
