Author Topic: Kickdown switch for 280SL  (Read 3017 times)
CJHenderson
  • USA, AR, Benton
« on: July 22, 2024, 22:50:28 »
It seems that there is no connector for my kickdown switch. I have looked everywhere inside my engine compartment with no luck. The wire color is red/black and brown/black.
https://www.sl113.org/wiki/Restricted/ColorWiringDiagrams
« Last Edit: July 22, 2024, 23:23:22 by CJHenderson »
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
lpeterssen
  • USA, FL, Miami
Re: Kickdown switch for 280SL
« Reply #1 on: July 23, 2024, 19:38:03 »
Dear Mr. henderson
The kickdown connector is normally in a loom in the cabin in the same one that has the hig/low beam switch , and then continues behind the carpet to the right.  It exits the cabin through a hole above the accelerator pedal.
Best regards
L.Peterssen
Www.wiredoktor.com
Ps later I Will post a picture of that loom
CJHenderson
  • USA, AR, Benton
« Reply #2 on: July 24, 2024, 00:08:09 »
Thank you for getting back to me.
1950 MG-TD
dirkbalter
  • USA, CA, Corona
« Reply #3 on: July 24, 2024, 00:20:05 »
Underneath the black tape, exiting the cabin as described above.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
  • USA, AR, Benton
« Reply #4 on: July 24, 2024, 10:17:15 »
Thank you, found the holes. I should have taken photos of that area when stripping the interior out.
1950 MG-TD
