Author Topic: 123 distributor fail - now success  (Read 3221 times)
merrill
« on: May 19, 2024, 20:19:36 »
hello
installed the 123 today,
followed the instructions, car started and idled, went to adjust the timing with my timing light.
car died.
went back, re did the installation, car still will not run.   every once in a while i get a pop
0 231 116 051 old disti, used a timing curve of "8", re using bosch red coil.
e mailed 123 for technical assistance
« Last Edit: May 20, 2024, 19:09:48 by merrill »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: 123 distributor fail
« Reply #1 on: May 19, 2024, 20:37:51 »
Wow, that's frustrating!
Keep us posted...
« Reply #2 on: May 20, 2024, 02:37:13 »
I always get confused with TDC - especially in the sense that there are two TDC's, one on compression stroke (that's the one we want to set ignition timing) and one on 'the other' stroke. It's very basic, and I always figure it out in the end, but I always have to be busy with it for a while, every time I need to 'time' an engine or ignition. So if it seems like you're on TDC, you may not be on the compression stroke and you have to rotate the engine again to what looks like the same point, but it's not, it's 'the other TDC'.
VikDasor
  • United Kingdom, England, Uxbridge
« Reply #3 on: May 20, 2024, 12:19:09 »
Hi Matt,
I had installed the 123 ignition while ago and I also remember I had to change the Ballast resistor too. May be look into that too.
Hope this helps.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
« Reply #4 on: May 20, 2024, 13:04:25 »
I always get confused with TDC...compression stroke
Found this to be useful: https://www.yourmechanic.com/article/how-to-find-an-engine-s-top-dead-center-by-ed-ruelas
For timing, the #1 piston at TDC on the compression stroke is the ONLY thing that matters. Note in the simple instructions on the link above, one of the first things they are having you do is ensure you are on the compression stroke.
If you are on the exhaust stroke (or "other") I don't think you'd see the marks line up on the balancer as it would be 180 degrees out...right?
When using a timing light after the fact--engine running and all that--you may find that the numbers and timing are hard to read. With the engine stopped and in near TDC position, best to clean the markings area and maybe highlight with white crayon or similar so you can better see with the strobe...
merrill
« Reply #5 on: May 20, 2024, 13:39:49 »
hello
thanks for the replies.
i went out before work on a very humid morning and found that the disti had popped out of the drive gear.
this is using the 123 clamp which is thicker than the oem.
will swap back to the mb clamp and try again.
now i am wondering if there is a memory in the 123 that needs to be cleared since it did work for a few minutes.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #6 on: May 20, 2024, 18:25:41 »
well,
ran home at lunch to mess with this.
after aligning the crank to "0" and the cam notch it seemed the rotor was 180 off.
ok, so rotated rotor, went to crank the car and the disti popped up out of gear.
decided to take a break and walk away for a while. but it i cant get it working i may just return the 123 and go back to setting points.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Paul & Dolly
  • i Car
« Reply #7 on: May 20, 2024, 19:01:43 »
It is unfortunately possible to fit the 123 distributor 180 degrees out.The drive lug is only very slightly offset so it is relatively easy to fit the 123 180 Deg out.
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
merrill
Re: 123 distributor fail - now success
« Reply #8 on: May 20, 2024, 19:11:46 »
ok,
so got it to work.
thinking about the disti popping out of the gear i ended up rotating the rotor 180 degrees until i felt the disti lock in.
re did everything per the instructions and it started on the first try.
i have the timing set at 6 -7 btdc and at high rpm its about 37
now to drive it and enjoy.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #9 on: May 20, 2024, 19:43:01 »
Those 180 degrees get us every time!
Glad to hear you got it to go, I am sure you will not regret having installed this upgrade.
Paul & Dolly
  • i Car
« Reply #10 on: May 20, 2024, 20:39:16 »
Glad it's sorted now
Paul
Mitsubishi i Car
« Reply #11 on: May 20, 2024, 21:38:30 »
so got it to work…ended up rotating the rotor 180 degrees until i felt the disti lock in…redid everything per the instructions and it started on the first try.
Fantastic!!!
dirkbalter
  • USA, CA, Corona
« Reply #12 on: May 20, 2024, 21:41:32 »
I agree.
(Don't blame the hammer if the nail doesn't go in)  ;)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #13 on: May 21, 2024, 14:15:34 »
I believe the vibration damper is also just slightly offset like the distributor drive so you "can't" install it 180* off. Not quite enough offset and you can "make" it fit. Not sure why, but seems MB should have made the offset just a tad more.
merrill
« Reply #14 on: May 21, 2024, 20:46:22 »
lots of good replies,
it would have been nice if MB had the cogs more offset so it was more obvious how to install the disti.
It had been a long time since i had to R/R the disti, kinda caused my own issue..  lol
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
MartinK
  • Germany, Hesse, Büdingen
« Reply #15 on: May 25, 2024, 07:57:52 »
Don't you think 37 advance is not a bit too much?  How did you proceed with the idle vacuum retard?
Jordan
  • Canada, ON, Jordan
« Reply #16 on: May 25, 2024, 10:55:00 »
Is it not possible to tell the difference between TDC on the compression stroke and the "other" (exhaust stroke) by looking at what direction the rotor is pointing?
Marcus
66 230SL  Euro 4 speed
MartinK
« Reply #17 on: May 25, 2024, 11:36:37 »
The most secure way is to have a look into the oil filler hole. There you can see the lobes of the camshaft cylinder 1. If the engine is TDC in compression stroke, the lobes are positioned upwards. If the engine is is in TDC gas exchange, the lobes are positioned downwards. There is no possibility to make a mistake.
« Reply #18 on: May 29, 2024, 20:41:48 »
GREAT INFORMATION!
« Reply #19 on: May 29, 2024, 21:33:03 »
No. 37 degrees is pretty close to where you want to have full advance. I often run 38 - 40 degrees depending on application.
1988 560SEC
