Author Topic: under dash wiring  (Read 4259 times)
jimpagoda
  • Canada, Quebec, laval
under dash wiring
« on: May 14, 2024, 01:27:16 »
i m working on a 1965 pagoda 230sl ,i need to know where to connect the 2 brass ground wires for the tachometer and speedo ,any photos for under dash will be appreciated
regards
Duncan200
Re: under dash wiring
« Reply #1 on: May 14, 2024, 06:39:04 »
They attach to the back of the speedo and tacho housings.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
WRe
« Reply #2 on: May 14, 2024, 07:09:21 »
Usually the ground wires for speedo and tacho are attached to the knurling nut when mounting the U-bracket. To simplify instrument installation, some people have drilled a threaded hole into the U-bracket to firmly mount the cable there.
The ground attachment at the body takes place on the left dashboard stiffener as far as I remember.
Here you can find some photos: https://www.sl113.org/forums/index.php?topic=27283.msg195756#msg195756.
...WRe
acbrock
  • USA, CA, Santa Monica
« Reply #3 on: May 14, 2024, 22:03:58 »
Oh boy. To add to my worries.  I did not have a ground on my Speedo.  Just the tach.  Back into the dash I go.
Leester
  • USA, VA, Lorton
« Reply #4 on: May 15, 2024, 00:10:15 »
"Oh boy. To add to my worries.  I did not have a ground on my Speedo.  Just the tach.  Back into the dash I go."
It just means your Speedo lights wont come on.
Lee Backus
1963 220SE Cabriolet
dirkbalter
  • USA, CA, Corona
« Reply #5 on: May 15, 2024, 02:22:35 »
regards
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #6 on: May 15, 2024, 17:19:58 »
...WRe
To avoid trying to keep the ground wires on the threaded stem while fiddling to screw on the nut I have extended the ground wires and attached them permanently at the bottom of the threaded stem.
This also allows me to pull out the tachometer (and speedometer) and let it hang down during the removal process.
« Reply #7 on: May 15, 2024, 18:05:33 »
jimpagoda - I would highly recommend you take the plunge and sign up for full membership. It will be the best $30 you will spend on your car. It gives you full access to the tech manual, two Pagoda World magazines per year, and four issues of our newsletter, Pagoda Notes.
jimpagoda
« Reply #8 on: May 18, 2024, 13:35:56 »
Thank you
