Author Topic: Alignment Tool  (Read 2888 times)
MP
  • United Kingdom, England, Devizes, Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Alignment Tool
« on: May 12, 2024, 12:00:00 »
In the Tec manual it gives three sets of measurements for the rear axle alignment tool, which is correct?
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
dirkbalter
  • USA, CA, Corona
Re: Alignment Tool
« Reply #1 on: May 13, 2024, 16:22:04 »
What are you talking about? Can you be more specific?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
MP
Re: Alignment Tool
« Reply #2 on: May 14, 2024, 07:24:29 »
Yes, although the totals are the same 877mm, three different offsets are given.
453/424.     460/417.    466/411.
2000 Ducati 748s
1970 Ducati Monza
dirkbalter
  • USA, CA, Corona
Re: Alignment Tool
« Reply #3 on: May 14, 2024, 16:39:12 »
The sketch for the alignment tool gives you the dimension to the pivot point of the axle, which is the one you are interested in, because that's the one you line up your tool to. The dimension to the center line of the chassis is of no real use for alignment purposes (if you are using the described alignment tool.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
MP
Re: Alignment Tool
« Reply #4 on: May 14, 2024, 22:40:16 »
Hi Dirk, I don't think I understand what you are saying, if the left and right sizes of the cross bar are changed doesn't that move the pointer left or right at the axle.
Maurice.
2000 Ducati 748s
1970 Ducati Monza
Re: Alignment Tool
« Reply #5 on: May 15, 2024, 05:19:04 »
When I did my tool I assumed one set of dimensions, 460 and 417.
The other drawing is chassis points measurements, not the tool measurements.
The third set of numbers I thought was a typo.
MP
Re: Alignment Tool
« Reply #6 on: May 15, 2024, 07:09:35 »
Thanks for the explanation Pawel I get it now.
Maurice
2000 Ducati 748s
1970 Ducati Monza
MP
Re: Alignment Tool
« Reply #7 on: May 16, 2024, 10:49:06 »
I don't know if it has been done but I used  15mm to 28mm connectors, they have a 25mm inside diameter which fits snugly over the nuts.
2000 Ducati 748s
1970 Ducati Monza
dirkbalter
  • USA, CA, Corona
Re: Alignment Tool
« Reply #8 on: May 16, 2024, 14:45:09 »
There you go. Make sure you set up the support arm properly (perpendicularity and distance) prior to installation.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
MP
Re: Alignment Tool
« Reply #9 on: May 16, 2024, 21:44:57 »
Have done that, thanks Dirk.
2000 Ducati 748s
1970 Ducati Monza
