Author Topic: Steering play  (Read 1600 times)
sens
  • Netherlands, North Brabant, Drunen
Steering play
« on: May 03, 2024, 13:56:08 »
Hello Pagode friends,
I did an overhaul on my power steering box. Quite an adventure, but all went well!
The adjustments you can make is the "friction" of the steering wheel movement (torque) and the friction of the Pitman arm.
I believe you cannot adjust the radial play in the steering wheel. (should be less than 25 mm according to the BBB)
In my case it is approximately 20 mm.
Is that correct?
Halvor Sens
