Author Topic: 230SL gear linkage bushing help.  (Read 2719 times)
georgem
« on: April 27, 2024, 03:10:11 »
I have just replaced all (or nearly all) linkage bushings in my gear lever - the only two that are giving me grief ( to the point of having destroyed two and needing to order two more from SLS )... are the two nylon bushings that fit into the SHIFTING SHAFT (SLS part # 28 - comes out of the back of the gearbox) -  and the SHIFTING ROD FORK FLANGE (SLS part # 24) There was no way that I could get the fork to slide over the new bushings so I (foolishly?) ground them down a bit, then a bit more etc until the forks fitted over them but the fit was too sloppy.
So, is there a proper/easy/hack means of fitting them?  All suggestions welcome.
Regards
George
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
Duncan200
  • 05-02-25 Just finished my Restoration
Re: 230SL gear linkage bushing help.
« Reply #1 on: April 27, 2024, 07:37:07 »
Hi George,
Are the two bushes you’re talking about number 22 in the pic I’ve attached?
If so, I too am having difficulty getting these bushes to fit, so much so, that I can only get one side to comfortably fit between the fork and the rod.
I’m not sure if the bushes are perhaps different on the various models and a one size fits all approach has been taken and may not necessarily be correct.
I haven’t reached the point of putting my driveline back in yet, so it was a tomorrow problem, but it won’t be too far away.
I hope we can both find a solution.
Doug
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day has come and she is back on the road
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
georgem
« Reply #2 on: April 27, 2024, 12:47:01 »
Hi Doug, Yup, the're the ones.
George McDonald
Brisbane
230 Sl
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #3 on: April 27, 2024, 19:12:28 »
Heat them up in boiling water and quickly press them in.  There is a tool for pressing them in.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
georgem
« Reply #4 on: April 28, 2024, 02:16:18 »
Hi Badali,
Thanks for the tips: -the bushes sit nicely into the gear shift rod without help but I shall try the hot water trick - have you had any luck using this method?
George
George McDonald
Brisbane
230 Sl
« Reply #5 on: April 28, 2024, 03:46:30 »
... but I shall try the hot water trick ....
George,
Hopefully you fit new bushings, not your modified ones.  I've not done this, but now that Brad mentions it and shows the tool, it reminds me that quite a few members have used this tool and hot water successfully.  Proceed!!  Maybe you can resell the tool to Doug.
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #6 on: April 28, 2024, 12:03:37 »
Hot water makes them a little easier to press in.  I also used a hair drier to warm them and it works well also.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
Duncan200
« Reply #7 on: May 01, 2024, 07:29:57 »
So I heated them with a hairdryer and attempted to slide the fork over.
As you can see from the pic, the fork is not wide enough for the bushes to slide in.
Perhaps I’m doing something wrong, but I can’t see it going on unless I thin down the bushings.
Doug
JohnnyC
  • USA, CA, Escondido, CA
« Reply #8 on: May 01, 2024, 12:56:54 »
George, Could it be your shift linkage is installed backwards. I had no problems installing mine. I purchased new plastic  bushings from Authentic Classics. I’m not sure if the earlier 230s use the same components as mine or not.  Cheers and God Bless, JohnnyC
« Last Edit: May 01, 2024, 13:10:21 by JohnnyC »
John
'70 280SL (In Rebuild), Dk Olive/Cognac
'85 BMW Euro M635csi, Polaris Silver
'54 MG TF, Black
'01 Lazy Daze RV, White/Tan
'10 Genesis Coupe, Silver
'19 F150, Black
Duncan200
« Reply #9 on: May 01, 2024, 13:12:04 »
Hi All,
Neither George or myself are going mad thankfully.
Here’s another post that reports an issue with the bushes.
https://www.sl113.org/forums/index.php?topic=33379.0
They will just need to be filed thinner.
Doug
BobH
« Reply #10 on: May 01, 2024, 14:41:03 »
Part numbers are on here if it helps, perhaps your supplier has sent the incorrect ones?  Shouldn't have to start modifying them
https://www.sl113.org/wiki/TransmissionClutch/Shifter#ManualShifter
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
georgem
« Reply #11 on: May 05, 2024, 20:53:20 »
Well, its in and all buttoned up - a test drive has proven that everything is A OK -gear changes are now very precise, but be assured that getting those two bushes in, for me anyway, ranks up there with installing the heater box under the dash :-\
I used a combination of hot water and silicone spray combined with a touch of brute force.
I removed the actuating rod from the tunnel and filed the edges of the forks to remove any burrs. I left the gear stick attached. I found a scrap piece of 2mm aluminium plate about 5cm x 15cm and wedged this underneath the gear shift rod (that comes out of the back of the gearbox - NOTE this should be in the fully forward position) - this formed a ramp and guide for the forks to slide up and onto the Gear shift rod. Next, I installed the two hot water-soaked bushes and held them in place with a 15cm set on vice grips - lined the forks up, sprayed the silicone and levered the shaft forward with a bit of wood that I had on standby. After a bit of wiggling of the gear lever, the forks slid forward, and I quickly installed the bolt - JOB DONE!!!
So.......thanks everyone for the suggestions, esp the hot water, - without that I don`t think the silicone spray alone would have done the job
George McDonald
Brisbane
230 Sl
