Author Topic: Fuel damper. What happens if it fails?  (Read 2283 times)
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
« on: April 18, 2024, 12:37:35 »
I have found details how to rebuild the fuel damper, but what are the engine symptoms if it fails?
 Cant find the answer if someone could point me to that please?
Trying to understand the symptoms and the knock-on effects to understand if my one is failing. (1966 230)
Many thanks.
ctaylor738
  • USA, VA, Falls Church
Re: Fuel damper. What happens if it fails?
« Reply #1 on: April 20, 2024, 12:51:15 »
A few years ago, I worked on a 280sl with multiple problems.  One was that the engine would barely run once fully warmed-up.  It turned out that the diaphragm in the damper had disintegrated and blocked the fuel return, causing the fuel pump to overheat.  I replaced the damper and blew out the return line and the car started running well enough to address its other issues.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Paul99
« Reply #2 on: April 21, 2024, 09:43:20 »
thanks.  I was wondering if this could be a cause for hot starting issues?  Will get it checked.
