Author Topic: Brake Line Axle Clamp  (Read 3106 times)
TJMart
  • USA, NC, Matthews
« on: April 03, 2024, 20:13:49 »
This clamp holds down the rear brake lines to the rear axle. Can anyone tell me what this clamp is called and where can I find these to replace them?
 I've tried the usual sources and I cannot locate them.
Thanks in advance.
Tony
Tony
1970 280SL, 4 Speed
BobH
Re: Brake Line Axle Clamp
« Reply #1 on: April 03, 2024, 21:19:52 »
Hello Tony, have a look on here, not sure of the proper name, it's a strap type clamp with a cotter pin, you buy the parts separately depending on the length you need, still available it seems from a few sources
https://www.sl113.org/wiki/Engine/HosesClamps
https://www.authenticclassics.com/Cotter-Type-Hose-clamp-kit-5mm-9mm-Sizes-p/auth-003406.htm
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
TJMart
  • USA, NC, Matthews
« Reply #2 on: April 04, 2024, 13:34:24 »
Thanks BobH! Never thought it would be under hose clamps but glad Authentic Classics carries the replacement.
Tony
1970 280SL, 4 Speed
« Reply #3 on: April 04, 2024, 14:55:46 »
I use the "cotter clamp" name, but I believe they are Beru clamps. As Bob H indicated pretty easy to find. The brake lines will use the 9 mm banding. They should not be painted, and will be the silver metal.
The small rubber covers on the brake lines should be available.
As a note, these are the same rubber items used on the hood rod.
« Last Edit: April 07, 2024, 15:12:55 by Jonny B »
« Reply #4 on: April 04, 2024, 16:18:15 »
Thanks BobH! Never thought it would be under hose clamps ...
Original cars will have these clamps in a few places under the hood.  Entrance and exit of heater core comes to mind.
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #5 on: April 04, 2024, 18:49:04 »
I had most of the original clamps like this on my car when I bought it.  How do you install these clamps?
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
TJMart
  • USA, NC, Matthews
« Reply #6 on: April 04, 2024, 19:04:15 »
I use the "cotter clamp" name, but I believe they are Behru clamps. As Bob H indicated pretty easy to find. The brake lines will use the 9 mm banding. They should not be painted, and will be the silver metal.
Thanks for the tips Jon!
Replacing my brake lines so now is the time to do it correctly without the black paint and also replace the rubber items I ordered from the Classic Center.
Tony
Tony
1970 280SL, 4 Speed
TJMart
  • USA, NC, Matthews
« Reply #7 on: April 04, 2024, 19:12:13 »
Take a look at BobH's post and use the link to the technical manual. It gives you a pretty good idea how to do it. The Kit sold by Authentic Classics also is supposed to have directions.
I have never done it myself but hopefully I'll figure it out.
Ill post an update when I getter done.
Tony
Tony
1970 280SL, 4 Speed
« Reply #8 on: April 04, 2024, 20:01:28 »
I've done it.  It's not too hard the 3rd time you do it.  Having the room to use a tool to twist the cotter pin is the key.
« Reply #9 on: April 07, 2024, 15:31:23 »
A small screwdriver works reasonably well. I took a medium size nail (sorry about the unclear sizing here it should be 2.5 cm/.10 inch) and bent the tip of the nail to 90 degrees it helps in some of the tight spaces. I think you need about 1-1.5 cm bent over.
See attached photo.
The kit from Authentic Classic does include two small metal rods, one large, one small.
Note that the later 280 SLs harmonized all the clamps to use the Norma style. The change occurred at VIN ending 16063 (13 Feb70) Listed in Pagoda Notes Vol 11 No. 3 - which is available in the Technical Manual.
« Reply #10 on: April 09, 2024, 04:44:47 »
The 190SL Group website (under technical info.) has a whole section on these and other early OEM clamps. They have part numbers, diagrams and instructions on how to use them. No membership is required to access their technical information.
