Become a
Full Member
Emergency Contact List
Electrical and Instruments
Alternator Fanbelt does not fit.
Topic: Alternator Fanbelt does not fit. (Read 2737 times)
CJHenderson
Full Member
Gold
USA, AR, Benton
February 09, 2024, 18:44:59 »
I have a 10x850 fanbelt that does not fit my alternator/water pump/crank pully. I do not have AC in the car. What size should use?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
alchemist
Associate Member
Senior
USA, NY, GRAND ISLAND
Re: Alternator Fanbelt does not fit.
February 09, 2024, 19:06:23 »
850 means 50 inches long. The AC should have a separate belt. I recently replaced my fan belt and it took 54 inches. The best way to measure the length use a thread run it around the water pump pulley and the Alt pulley. The best and cheapest place to buy belts measured by inches is Home Depot on line. Good Luck.
CJHenderson
Full Member
Gold
USA, AR, Benton
Reply #2 on:
February 09, 2024, 20:10:19 »
I have neither AC or the bracket that the compressor and alternator would be attached to, I have the OEM bracket that have the alternator sitting lower.
1950 MG-TD
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #3 on:
February 09, 2024, 21:03:07 »
This is what parts list is saying and what I bought:
A 004 997 95 92 V-BELT replaced with A 006 997 09 92
A 006 997 09 92 V-BELT 12,5 X 750 MM
Price is about $15 here.
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Reply #4 on:
February 10, 2024, 07:16:57 »
Alternator
early
9,5mm x 875mm (A 005 997 8392)
9,5mm x 910mm (A 006 997 0292)
late
9,5mm x 935mm (A 006 997 3292)
Power sreering
12,5mm x 750mm (A 006 997 0992)
AC
13mm x 1075mm (A 001 997 4392)
Length +/- mm
Last Edit: February 10, 2024, 07:41:58 by WRe
