Author Topic: Parking Brake Removal - Left Thread  (Read 2866 times)
acbrock
  • USA, CA, Santa Monica
« on: January 10, 2024, 07:11:30 »
I was about to take out the brake tomorrow and thought I would read a little after destroying shifter Knob.  I turned and turned until I crushed it, then read I should have just popped it off!  Argh.. So the bolt were pretty stiff so I sprayed them to loosen them up and thought I would tackle it tomorrow.
Glad I read first.  Sounds like one of the bolts is Left Threaded!   Can anyone point out the Left one so I don't destroy it?  I could not find a good pick and I forgot to take one of my car.  But I found this pic on the site.  Is it this Big Bolt or the smaller one, that is just to the right and below the big one?
A
WRe
acbrock
Re: Parking Brake Removal - Left Thread
« Reply #2 on: January 10, 2024, 16:16:44 »
Wow amazing!  Thank you!  I cannot figure out why the did not come up on my search...
« Reply #3 on: January 10, 2024, 16:50:10 »
To learn more about the search functionality take a look at these issues of Pagoda Notes - all are posted in the technical manual
Volume 1 no 2
Volume 9 no 2
Volume 13 no 1
Happy hunting
« Reply #4 on: January 10, 2024, 18:19:32 »
Searching the Forums does not search the Tech Manual.  You have to do it separate.
acbrock
« Reply #5 on: January 10, 2024, 21:15:56 »
Ah!  Thank you.  I thought it searched everything!  That will be a big help!  Also reading the notes, getting the handbrake out was a piece of cake!
Thanks!
« Reply #6 on: January 12, 2024, 21:09:20 »
Great work.  You've been posting a lot of threads and doing a lot of work.  Very inspiring.
acbrock
« Reply #7 on: January 13, 2024, 22:05:20 »
Hmm. Got it cleaned up and was about to Reinstall... But when I put the spring in it falls a little past the bend?  Looking at this parts list I dont have the washer under the spring?  Any idea what it is?  I looked at all the parts I had when I took it apart and they are all in the picture of my hand brake?  I also dont have the piece at the top near the button in that diagram?
Hmm. Says the photo upload is not working....
Here is a link if anyone wants to take a look...
https://www.dropbox.com/scl/fi/iqezhhwpco5t22m2ddtqz/IMG_3754.HEIC?rlkey=n1b7g659mvfhnp1u6ghfvpava&dl=0
https://www.dropbox.com/scl/fi/lknhg8zeb8bjz6w3x6d4f/Part.jpg?rlkey=y637hi1x4j41zzbulla8v11b5&dl=0
« Last Edit: January 13, 2024, 22:16:54 by acbrock »
BobH
« Reply #8 on: January 13, 2024, 22:27:17 »
All parts available at Niemoller and probably other suppliers
https://www.sl113.org/forums/index.php?topic=33942.msg248362#msg248362
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #9 on: January 13, 2024, 23:17:55 »
You talk about washer under spring, A 198 427 00 76, you will not get it neither in SLS nor Niemoeller, but you will get it form the Mercedes dealer, ca $15-20.
The other part is the rubber boot around the button. This you will get everywhere, also at the dealers, A 198 427 00 96, ca $40.
Quick way to post a parts diagram is to use the snipping tool, save it as picture and then post it as picture.
acbrock
« Reply #10 on: January 13, 2024, 23:19:37 »
cool thanks.,  Man I never saw the piece but have been soaking my parts in Vinegar to loosen the rust.  I went and dumped out this big old pickle jar I am using to do the long parts and there it was at the bottom!  Wahoo..
