with our official
Pagoda SL Group logo
from our official partner.
fuel pump fuse blowing
Topic: fuel pump fuse blowing (Read 2263 times)
edwardburak@erols.com
Inactive
Regular
USA, VA, Marshall
November 10, 2023, 18:17:29 »
Hello have a 1969 280 sl doing a total restoration
Just recently l have had the fuel pump fuse #4 Blow when turn ignition switch on . any ideas where to start looking , ' engine had run before , with a new fuel pump. Any help thanks
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: fuel pump fuse blowing
November 10, 2023, 19:21:40 »
Have you replaced the fuse and did it blow again?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Kevkeller
Full Member
Silver
USA, HI, Honolulu
Reply #2 on:
November 10, 2023, 20:53:53 »
Remove the wire on the pump and replace the fuse. See if it blows again. If it does it’s probably not the fuel pump but a short somewhere.
1970 280 SL
roymil
Full Member
Senior
USA, TX, Austin
Reply #3 on:
November 12, 2023, 20:05:46 »
"New" fuel pump probably actually means rebuilt. I know the first time I rebuilt mine I wasn't particularly careful about polishing the impeller and double checking that it spun freely with the cover on. It was noisy and eventually stopped and blew the fuse when it did. I pulled the bottom cover and polished up the impeller and the mating surfaces really well to get it going smoothly again.
Mark Miller
1968 280SL
Rode in his pagoda's first mile.
Inactive
Regular
USA, VA, Marshall
Reply #4 on:
November 12, 2023, 22:44:25 »
yes continues to Blow the fuse
afibbe
Full Member
Senior
USA, OH, Cincinnati
513-374-5600
Reply #5 on:
November 16, 2023, 18:48:15 »
The first thing I would look at are the wires that come down through the trunk.
When I removed my pump, I found the wire insulation under the plastic wire sleeve in poor condition. It is possible that moving the wires during the pump work has caused a short.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
