Author Topic: Right Rear Wheel Bearing 1208  (Read 2771 times)
Duncan200
« on: October 12, 2023, 23:55:57 »
Hello All,
I had a quick look around the forum to see if anyone had encountered this issue and I can’t seem to see anything relating to it.
I’ve purchased an SKF 1208 EKTN9/C3 bearing as seen in an earlier post regarding these bearings.
The problem I have is that it slides straight on to the axle, no pressing of the inner race required.
I have measured the inner diameter of the old bearing vs the new and the old measures 40.00mm and the new 40.87mm.
Whilst I know that it is tightened to 200nm , I’m a little concerned about it just sliding on and not requiring any pressing.
I thought I’d put my dilemma to the knowledge of the group before I look to order another bearing somewhere else.
I guess I need to know if the new bearing would be ok, given it’s done up tight and won’t spin or do I err on the side of caution and order another bearing?
Thoughts anyone?
Thanks Doug.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
dirkbalter
  • USA, CA, Corona
Re: Right Rear Wheel Bearing 1208
« Reply #1 on: October 13, 2023, 00:26:47 »
40.87 versus 40.00 is way too much. Not even close. You have the wrong bearing.
Can you add the link to the post you are referring to?
One side (left) is a ball bearing, the other side (right) is a roller bearing.
Both are 40 x 80 x 18.
Looks like you have a tapered bearing.
https://www.skf.com/us/products/rolling-bearings/ball-bearings/self-aligning-ball-bearings/productid-1208%20EKTN9
« Last Edit: October 13, 2023, 01:08:33 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Duncan200
« Reply #2 on: October 17, 2023, 02:31:22 »
Hi Dirk,
This is the post I am referring to.
https://www.sl113.org/forums/index.php?topic=22226.0
You are correct it is the incorrect bearing, although it is self aligning. There is some conjecture in this post and after discussing this with my parts supplier, I am going to get the correct barrel type bearing.
I’ll chalk the money I spent on this bearing up to experience.
Thanks for your response.
Doug.
