Author Topic: UNDER DASH PAD-LEFT  (Read 4538 times)
Bshaunessy
  • Canada, British Columbia, Invermere
  • 1957 190 SL; 1970 280 SL; 1975 450 SL; 1971 300 SE
UNDER DASH PAD-LEFT
« on: October 03, 2023, 14:10:49 »
Hi…..WTB: LEFT SIDE UNDER DASH PAD
  To fit 1970 280 SL left hand drive. See pics.
doitwright
  • USA, IL, Willowbrook
Re: UNDER DASH PAD-LEFT
« Reply #1 on: October 03, 2023, 15:51:07 »
If no one has one here, they can be found on ebay.
Frank Koronkiewicz
Willowbrook, Illinois
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #2 on: October 03, 2023, 16:43:13 »
We have templates in the full member site, you  could make one
https://www.sl113.org/wiki/Restricted/UnderdashAndTrunkPanelTemplates
Lori
1968 280SL (US)
« Reply #3 on: October 03, 2023, 17:46:16 »
And at many traditional vendors, but probably only as a full set.
Bshaunessy
« Reply #4 on: October 03, 2023, 19:58:07 »
Thx all for the helpful responses:
(1) found right hand under dash pad on EBay but so far , no left hand under dash pad….hence the post in WTB section.
(2) similarly, can’t find at Authentic, Buds, K&K, Vintage euro parts…….Q? maybe I’m searching the wrong description? "DASH PAD", "UNDER DASH PAD"????  Q? Alternate suppliers that might have?
(3) good tip RE templates available……might be beyond my capabilities as these pads appear to be foam ( easy to cut) but covered with black vinyl or is it MB-TEX? ( not so easy to source)
Bshaunessy
« Reply #5 on: October 03, 2023, 20:14:52 »
Link on this website provided by LORSTAR is for templates for "UNDER DASH PANEL SET". I believe these are installed under the dash to cover up the instrumentation etc from below?  Amy car does not have any of the three shown in the template section.
To clarify , I am looking for left side "UNDER DASH PAD".   Schematic from Vintage Euro Parts catalogue attached.
BobH
« Reply #6 on: October 03, 2023, 20:15:23 »
Hello, half the battle is knowing what to search for
Full set available here
https://www.authenticclassics.com/250SL-280SL-113Ch-3pc-Underdash-Panel-Set-p/auth-002804-0002.htm
I would think most of the usual vendors sell them, just need to be creative when you search!
Apologies, posted this exactly the same time as you posted the clarification, wrong panels completely
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
lreppond
  • USA, CA, San Leandro
« Reply #7 on: October 03, 2023, 21:17:23 »
I believe you are asking for something different than what other members are referring to.  If I’m understanding you correctly, you’re looking for the molded/padded piece of dash covering that fits to the left of where the steering wheel column fits into the dash NOT the cardboard panel that fits under that?
If my assumption is correct, you’re looking for something more difficult to source.  The actual part is NLA. That being the case, you’ll need to look at the secondary market.  Although eBay has had them, have you asked Nelson at Vintage Euro?  He carries some used dash pieces or may be able to source it for you.
It will be covered in the same MBTex or leather that the rest of your dash is covered.  I’d opt to get a pad covered in any color you can find and then recover it in material matching the rest of your dash.  If it’s black, that’s an easy do.  If it’s something more exotic, maybe more searching on your part.
Please let me know if I’ve understood your request or not.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
Lori
  • 1968 280SL (US)
« Reply #8 on: October 03, 2023, 21:48:37 »
Lori
1968 280SL (US)
doitwright
« Reply #9 on: October 03, 2023, 22:36:12 »
Ebay.com
search w113 dash
One for $110, Another $368. You will also need the chrome trim if you do not have it.
Frank Koronkiewicz
« Reply #10 on: October 04, 2023, 03:54:50 »
... but covered with black vinyl or is it MB-TEX?
Same thing???
Bshaunessy
« Reply #11 on: October 04, 2023, 14:21:46 »
GENTLEMEN
  Thx for the help.  Supply chain issues solved: sourced a used under dash pad Vintage Euro Parts ($325!) and the chrome trim piece ( that I didn’t know I needed!) on EBAY ($$120 !).  Parts for these beauties certainly are expensive!
