Author Topic: 230SLs & 250SLs - Leaking Red Oil Cap on Left Side of Motor  (Read 8074 times)
BobH
Re: 230SLs & 250SLs - Leaking Red Oil Cap on Left Side of Motor
« Reply #25 on: September 08, 2023, 10:49:05 »
Hello Cole, what model pump do you have?, it's stamped on the plate on the pump
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Paul & Dolly
  • i Car
« Reply #26 on: September 08, 2023, 13:10:54 »
Cole
I think there will be a dipstick, look at my earlier photo, and follow the yellow dots
.. is not easy to find, hence I painted it yellow
It is low down .
Good luck
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
« Reply #27 on: September 08, 2023, 13:25:02 »
These pics help?
Yes, the dip stick is a PITA to get to and use.
Did you know you can search our site specifically using Google?  I "image search" with Google using search strings like this - "bosch R11 fuel injection pump dip stick site:www.sl113.org"
And, knowing that this can be done is a reminder that almost our entire forum is open to viewing by the public, the whole world can see what you post.  That's why we recommend you do NOT post phone numbers, email addresses, physical addresses, or any other personal info.  Use the forum tools to send emails and PMs to share personal info.
« Last Edit: September 08, 2023, 15:40:45 by rwmastel »
lagolag
  • Sweden, Västra Götaland, Askim
« Reply #28 on: September 08, 2023, 19:09:25 »
I ha dthis issue up last year, se link
https://www.sl113.org/forums/index.php?topic=35115.0
230SL 1967 since July 2021
SL55 AMG 2003 since July 2008
Suzuki Cappuccino 1995 since May 2006, Sold
« Reply #29 on: September 08, 2023, 20:15:19 »
Lars,
Did you pump get serviced over last winter?  Full rebuild or just select parts replaced?  Does the oil level stay as it should?
Cole
  • USA, CA, Los Angeles
« Reply #30 on: September 10, 2023, 09:28:55 »
Hi guys,
I had the fuel injection pump removed yesterday from my '67 250SL and am considering having it serviced/rebuilt.
Can anyone recommend a good, reliable shop that does this, preferably in So. Calif. But will consider elsewhere if necessary.
Also, does anyone know if Bosch services/rebuilds these older pumps?
If so, can you reply with their contact info?
Thanks.
Cole
Cole
'69 280SL, 40G Black/Burgundy Interior
glcg123
« Reply #31 on: September 10, 2023, 12:25:11 »
I used this guy. He not only rebuilt my pump with new seals, he also calibrated it with Bosch calibration equipment from the 1960's era.
My car had never run better because it was running too rich for quite a few years. He has parts for these old pumps.
Jerry Fairchild Industries
29786 Westmoore Rd, Shingletown, CA 96088, United States (Northern California)
Phone: +1 530-474-4646
www.fuelinjectioncenter.com
He does great work!
Cole
« Reply #32 on: September 10, 2023, 19:48:22 »
As many of you have indicated in this thread, if the injection pump hasn't been rebuilt/thoroughly cleaned for many years and it's leaking or not functioning up to par, just get it done.
Many thanks to you and all the others here who gave me a lot of helpful feedback regarding this fuel pump's issues.
Cheers.
Cole
Cole
lagolag
« Reply #33 on: September 16, 2023, 09:20:33 »
Rodd,
No, I decided to wait as the car runs well, I have put my time in replacing bushings in the front section, coming winter I’ll do the rear end bushings and gearbox change to 5-speed Getrag 265/6. But as soon as I get problem with the Injection system I’ll have the FIP serviced.
