Author Topic: Speedometer Dial  (Read 3591 times)
Pagoda730
  • USA, NY, Scarsdale
Speedometer Dial
« on: August 28, 2023, 07:31:10 »
My speedometer dial has a silver disk (about 13 mm in diameter) at the zero Km/H location.  It otherwise looks original.  See picture.
Any idea what this might be?
My car is a 1963 230 SL that otherwise seems pretty original.
« Last Edit: August 28, 2023, 07:44:12 by Pagoda730 »
MP
  • United Kingdom, England, Devizes, Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Re: Speedometer Dial
« Reply #1 on: August 28, 2023, 07:41:22 »
Looks like it's from the centre of the dial
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
Pagoda730
« Reply #2 on: August 28, 2023, 07:48:41 »
Of course.  Thank you.   Must have fallen off.  Any idea how this is attached at the center of the dial?
« Reply #3 on: August 28, 2023, 13:20:24 »
My guess would be either a press fit or some glue.
« Reply #4 on: August 28, 2023, 14:17:35 »
Very fragile metal underneath, same as the needle, I would go for a drop of glue...
« Reply #5 on: August 29, 2023, 01:38:18 »
Pagoda730,
You posted in the Full Members board.  Most Members are not Full Members, so they have no access to this discussion.  I'm moving this discussion to the Electronics and Instruments board as the topic fits that board and all Members have access.
Thanks.
« Reply #6 on: September 01, 2023, 04:42:22 »
It is originally glued. A bit of clear silicone works well. Be careful to use some gloves handling the disc. It is raw, machine turned aluminum and the oil from your skin will discolor it if not handled correctly.
